Author Topic: Help with X-arcade controller...  (Read 13675 times)
Ichabod15
  • Last login:May 01, 2003, 10:30:51 am
  • MVS addict
Re:Help with X-arcade controller...
« Reply #40 on: May 08, 2003, 06:38:10 am »
Ciro told me that he don't know much about electronic...
He told me that the i-pac have a lot more of ghosting problems than the x-arcade's pcb... is it real ?
If the I-pac don't suit me, I'm gonna store it somewhere until I can find an old arcade cab to plug into  ;D
Tiger-Heli
    • Tiger-Heli
« Reply #41 on: May 08, 2003, 06:45:46 am »
Check you Private Messages!
Ichabod15
  • MVS addict
« Reply #42 on: May 08, 2003, 07:02:57 am »
hmmmm....
Tiger-Heli
    • Tiger-Heli
« Reply #43 on: May 08, 2003, 07:12:29 am »
hmmmm....
I don't type that fast and it was a long PM, should be there now  8)
Ichabod15
  • MVS addict
« Reply #44 on: May 08, 2003, 07:20:24 am »
thanks, i don't check the time on the post... though you wrote it before posting... ;D
Tiger-Heli
    • Tiger-Heli
« Reply #45 on: May 08, 2003, 07:25:38 am »
No problem, that would have been the logical thing to do.  (When have I ever been logical?  :P)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #46 on: May 08, 2003, 11:08:21 am »
that *Can't* be right on several levels...   sounds like FUD to me.
I'm wondering why'll you'll spring for the ipac, but the cable/x-arcade adapaters would be too  much of an investment (although I understand the shipping/tax rivals the cost of the actual item(s)))
*shrug*
rampy
ONE note to the wiring of the "serial" connection cable thingie... I'm NOT positive (i don't even own a x-arcade) but i'm pretty sure MOST of the "adapters" have some sort of logic and chip in them (i.e. they aren't just ways of connecting to different plug styles -- something else goes on in the translation.  I know its that way for the console adapters, but have no idea if that's the case for the PC/ps/2 or usb connectors.
« Last Edit: May 08, 2003, 11:11:50 am by rampy »
Tiger-Heli
    • Tiger-Heli
« Reply #47 on: May 08, 2003, 11:11:42 am »
FUD???  I can guess what the first two letter mean . . . ???
Ichabod15
  • MVS addict
« Reply #48 on: May 08, 2003, 12:24:36 pm »
There are actually no way to get the replacement cable shipped to france... and I don't have anymore usb port free... I don't want to buy an hub (cause the usb cable+the hub should cost more than the i-pac and a few wires...)
[/quote]
rampy
  • *shrug*
« Reply #49 on: May 08, 2003, 02:38:46 pm »
Fear Uncertainty Doubt  (i picked it up from slashdot... usually used in a sentence describing M$ tactics to make linux look back by using FUD...
*shrug*
rampy
