Author Topic: Atomic FE Keycodes  (Read 784 times)
Dariusz
  • Last login:November 23, 2018, 02:41:36 pm
Atomic FE Keycodes
« on: September 16, 2007, 04:25:08 pm »
Hi,
I'm attempting to configure a Joy-to-key converter prorgame for use with Atomic FE, but before I do, I wish to understand the keycode representation against the physical key on the keyboard.
Can any one help me understand how I can convert an keycode, say 32, that is used on Atomic FE. I have searched for a table representation on google, buy there seems to be different keycodes for the same key?
Thanks,
Dariusz
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Atomic FE Keycodes
« Reply #1 on: September 17, 2007, 03:53:43 am »
Look here, at the end there is a table with virtual keycode for Windows and Macintosh. Of Atomic use the windows one.
http://classicteck.com/rbarticles/mackeyboard.php
More or less in windows Keycode of a key seems to match with the ASCII Code of the capital letter of key (but it is not the same thing at all).
If you want find the keycode of a key easily, you can use AtomicKey. If you try to define a new key , when you press on a key , it will display the keycode.
I hope it helps.
