Author Topic: HD cable, SATA to IDE??  (Read 1607 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: September 13, 2007, 08:52:23 am »
Do they make a cable that allows me to use a newer SATA hard drive with an older mother board with IDE hard drive inputs or whatever the older hard drive interface is called.
I b**ch. People listen!!
Neilyboy
  • Last login:October 08, 2025, 08:19:14 am
  • what day is it...
Austin.Wolff
  • Last login:February 04, 2011, 03:53:32 pm
Re: HD cable, SATA to IDE??
« Reply #2 on: September 13, 2007, 09:04:04 am »
Even inf you could, I don't see the point of buying a SATA drive to use it at IDE speeds.
severdhed
  • RIP Dinosaur Hippo
« Reply #3 on: September 13, 2007, 09:22:25 am »
maybe it is just a matter of he has a sata drive and doesnt want to buy a new one.
Green Giant
« Reply #4 on: September 13, 2007, 09:46:32 am »
A better option would be a sata pci card.  Then you could have the speed of sata on the computer you are using.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1431868&CatId=1455
Toxic Arcade, my first build
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
« Reply #5 on: September 13, 2007, 09:52:04 am »
I highly recommend SATA PCI cards; I've put them in all of my older IDE machines and have never had a bit of trouble. You get the speed, convenience, and futureproofing (FWIW) of SATA in a non-SATA machine.
squirrellydw
« Reply #6 on: September 14, 2007, 10:18:28 am »
thanks I will go with the card
squirrellydw
« Reply #7 on: September 21, 2007, 10:47:00 am »
are all sata connectors the same?  I am looking for a PCI card with internal sata 2 connectors for cheap.  Will sata 150 work with a sata 2 HD and just run slower?
So this http://www.newegg.com/Product/Product.asp?item=N82E16812206001
should work with this HD
http://www.newegg.com/Product/Product.asp?item=N82E16822148151
« Last Edit: September 21, 2007, 10:52:43 am by squirrellydw »
