Author Topic: Newb question  (Read 5864 times)
red_johnny
  • Last login:June 03, 2011, 02:35:17 pm
Newb question
« on: September 12, 2007, 03:18:15 pm »
When installing a 1 to 4 jamma adapter should I mount the card on the bottom so that I can stick the other cards straight down into?  If so would I need to take the cards out every time I move the cabinet?  I want to make sure I do everything right too.  There is a guide to this I bet.
arcadefever
  • Miami Beach Florida
Re: Newb question
« Reply #1 on: September 12, 2007, 04:03:19 pm »
hi,
are you talking about that one ???
red_johnny
Re: Newb question
« Reply #2 on: September 12, 2007, 04:06:18 pm »
I sure am! :applaud:
arcadefever
Re: Newb question
« Reply #3 on: September 12, 2007, 04:22:16 pm »
I have just installed one in my commando cab (i will post pictures later tonight)
what i did is, i build Jamma extensions, for that you need a jamma harness and a fingerboard.
the jamma harness goes to the pcb, and the finger board to each slot, that mean you will have to do some work on it (solder the wires to the finger board)
that solution give you the possibility to secure all the pcb and the main 4in1 board to the cab, and moving the cab wont be a problem...
you also can put the 4in1 in the bottom of the cab, and slide the pcb vertically in it, the problem is depending on the weight of each pcb  :-\ if to heavy, it can bend and broke the slot on your main 4in1, moving the cab will be recommended without the pcb inserted ...
unless you found a way to secure them so they do not move  :P
red_johnny
Re: Newb question
« Reply #4 on: September 12, 2007, 04:32:29 pm »
Thats a really good idea.  I thought about looking for something like that but I could not find it.  So I need then, to buy 4 harness's and 4 finger boards.
arcadefever
Re: Newb question
« Reply #5 on: September 12, 2007, 04:35:57 pm »
yep, 4 harness, and 4 finger boards,
you rewire the end of the harness to the FB...and you should be good to go...
red_johnny
Re: Newb question
« Reply #6 on: September 12, 2007, 05:03:29 pm »
Ok, do you know where I can get some cheap harness's? :dizzy:
arcadefever
Re: Newb question
« Reply #7 on: September 12, 2007, 05:38:08 pm »
ebay, will be a good start to look...
ps: make sure your 4in1 as the pin 14 on the part side  grounded...
red_johnny
Re: Newb question
« Reply #8 on: September 12, 2007, 05:57:45 pm »
er...I really dont know what I am looking for as far as the Pin 14 goes
arcadefever
Re: Newb question
« Reply #9 on: September 12, 2007, 06:07:47 pm »
dont worry, i will post a picture of it later tonight  ;)
red_johnny
Re: Newb question
« Reply #10 on: September 12, 2007, 07:00:48 pm »
:applaud: :applaud: :cheers:
arcadefever
Re: Newb question
« Reply #11 on: September 12, 2007, 10:25:15 pm »
as you can see, it is a little blue wire, that conect pin 14 on the pcb (part side) to the 1st pin (GRND)
 it is a bit crowded  ;D 4 pcb in the commando cab...
-commando
-contra
-gun smoke
-bagman
« Last Edit: September 12, 2007, 10:27:45 pm by arcadefever »
red_johnny
Re: Newb question
« Reply #12 on: September 13, 2007, 07:33:44 am »
WOW!  Thanks for the pics.  I will check out the board tonight to see if it was grounded or not.
red_johnny
Re: Newb question
« Reply #13 on: September 13, 2007, 10:01:00 pm »
Thank goodness mine has that wire.  I was afraid I would have to do it myself!
arcadefever
Re: Newb question
« Reply #14 on: September 13, 2007, 10:25:17 pm »
red_johnny
Re: Newb question
« Reply #15 on: September 16, 2007, 03:59:51 pm »
Question for you, what kind  of power supply are you useing?  I figure I might have a problem with my current one as I dont know if it works correctly or not.  I plugged in pit fighter and I did not get any sound.  I dont have a tv hooked up yet but I thought I should at least have sound.
arcadefever
Re: Newb question
« Reply #16 on: September 17, 2007, 01:15:54 am »
make sure that you have connected the -5 v
to the pcb... that probably why you do not have any sound  ;)
(not all games use -5) but that one does ...
for PSU you can find some on ebay for cheap ...
red_johnny
Re: Newb question
« Reply #17 on: September 17, 2007, 04:52:30 am »
Do I need a specific rating like 300 watts?
red_johnny
Re: Newb question
« Reply #18 on: September 19, 2007, 05:35:39 pm »
I am refering to the power supply.  If I run 4 cards would I need 300 watts of power?  Also, how did you wire everything?  Kick harness?  Is there a book or guide some where I can get to start wireing this thing up right?  Where did you buy your figer boards from?  Sorry about the enslaught of questions, just tring to plan and get this thing done :cheers:
arcadefever
Re: Newb question
« Reply #19 on: September 20, 2007, 12:49:58 pm »
you do not need a 300 watts PSU...because the 4in1 power only one game at a time.
when one is on, the 3 others are off...
the best way to wire all pcb to the 4in1, is to buy jamma harness, and jamma fingerboard
all of this can be found on ebay...
Level42
Re: Newb question
« Reply #20 on: September 20, 2007, 01:13:00 pm »
If you are already afraid of soldering that one tiny wire, how are you going to deal with the fingerboards/harnesses ?
I'd like to have one of those 4 in 1, where did you get them ? (That is if it's not from E-bay)...
arcadefever
Re: Newb question
« Reply #21 on: September 20, 2007, 01:19:28 pm »
ebay  :cheers:
red_johnny
Re: Newb question
« Reply #22 on: September 20, 2007, 03:33:27 pm »
Same here :cheers:
ebay  :cheers:
