Author Topic: Does dreamcast have to be in composite sync or can H & V be seperated still?  (Read 2006 times)
northerngames
  • Trade Count: (+18)
Does the sega dreamcast have to be in copmposite sync only or can H & V be seperated still?
also since the dreamcast was made for compossite where H&V are together but if they can be seperated would the display results still be the same and would the light guns still work like normal?
also was wondering if I had one console on composite sync and another on H & V sepaerated would the screen display scroll roll or flip when I switched between the two and have to adjust the screen each time?
or once the H & V are set right I could swap from either and have a still correct display?
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
No, swapping H & V syncs on any input will NOT flip/rotate/change the picture orientation.
