Author Topic: CRT vs CGA  (Read 1966 times)
Austin.Wolff
  • Last login:February 04, 2011, 03:53:32 pm
CRT vs CGA
« on: September 09, 2007, 07:09:53 pm »
Seeing as arcade monitors at 27" seem to be in the $500 range, I figured I'd look at 27" crt monitors, which you can basically pick up for you.  Do you figure its worth it to use until I decide to buy an arcade monitor?  How different is the picture?
Austin.Wolff
Re: CRT vs CGA
« Reply #1 on: September 09, 2007, 10:48:59 pm »
Oh, and I more or less figured this out.  I booted up mame on my laptop and 27" TV, looks pretty good.  Nothing I'm going to be running is THAT odl, so I think I can get by.
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
Re: CRT vs CGA
« Reply #2 on: September 10, 2007, 10:54:34 am »
I say get whatever you can live with.  If this is your first cab and you are playing mostly newer (90’s) games, I say go with a TV.  No use paying $300 extra if you just want to play the games and have fun.  Much cheaper, and usually easier to set up.  May be a little tricky to mount in a cab, but it can be done easily.
If you want authentic arcade resolution, get a CGA arcade monitor.  You will probably spend lots of time experimenting with proper resolutions and settings for each game.
Personally, I have a 27" TV in my first MAME cab and I am very happy with it.
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
ARTIFACT
Re: CRT vs CGA
« Reply #3 on: September 10, 2007, 07:14:29 pm »
what did you use, S-Video (most older TVs) or straight to VGA or DVI (recent TVs have those now)?
Austin.Wolff
Re: CRT vs CGA
« Reply #4 on: September 10, 2007, 08:29:21 pm »
S-video.  The screen was blurry for windows etc but using a front end it looks great.
