Author Topic: G-07 grey screen  (Read 2864 times)
t8erbug
  • Last login:November 28, 2008, 02:33:41 am
G-07 grey screen
« on: September 01, 2007, 08:34:51 pm »
I received a Missile Command with no picture. I did a cap. kit with flyback form Bob. Unfortunately all I get is a gray screen. I but the board from a working G-07 in and it and I get the same thing. I don't see anything lighting up in the neck of the tube. Any suggestions where to look next.
« Last Edit: September 01, 2007, 08:41:30 pm by t8erbug »
SirPeale
  • Green Mountain Man
Re: G-07 grey screen
« Reply #1 on: September 01, 2007, 08:45:19 pm »
If the screen is grey and slightly lit, I would suspect it's not getting a signal.
Turn up your screen control on your flyback.  Does the screen turn white?
t8erbug
« Reply #2 on: September 01, 2007, 08:51:46 pm »
It lightens up but never gets white. I also checked voltages coming to the neck board and all are present. The board I'm using works fine on another G-07
« Last Edit: September 01, 2007, 09:01:55 pm by t8erbug »
Kevin Mullins
    • Me on Myspace
« Reply #3 on: September 01, 2007, 10:30:04 pm »
Game board? or Monitor chassis?
Sounds like the monitor is working...... the game board is not.
SirPeale
« Reply #4 on: September 01, 2007, 11:15:56 pm »
I agree with Kevin.  Unless the game plays blind.  That is, you credit the game and get game sounds with no picture?
t8erbug
« Reply #5 on: September 02, 2007, 01:29:32 pm »
The monitor board works fine in another chassis. The RGB and Sync wires coming to the monitor board from the game board are reading 4v dc each on the RGB and 3.8v and 1v on the sync.
« Last Edit: September 02, 2007, 01:32:15 pm by t8erbug »
Kevin Mullins
    • Me on Myspace
« Reply #6 on: September 02, 2007, 02:24:36 pm »
Does the game play WITHOUT the monitor connected?
t8erbug
« Reply #7 on: September 02, 2007, 07:45:17 pm »
I don't get any sound out of the machine when i turn it on. So I'm assuming no. Ill try to get a reading out of the sound board.
