Author Topic: What would happen?  (Read 2134 times)
TexasWalter
  • Last login:January 27, 2012, 04:59:11 pm
What would happen?
« on: August 30, 2007, 05:29:43 pm »
What would happen if I installed a standard resolutionmonitor in place of a medium resolution?
And what would happen if I installed a standard resolution chassi in a med resolution chassi?
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
Re: What would happen?
« Reply #1 on: August 30, 2007, 08:03:51 pm »
You would not get a useable picture
Assuming the tube and yoke were compatable with the chassis in question, this would work.
Regards,
D
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #2 on: August 30, 2007, 09:06:36 pm »
D is right on the first one, the picture would not be in sync.
The second one, the yoke will not be compatible, a CGA/Standard res yoke is 1.0 mh or higher, a Mid res is around .6.
Even if you are lucky and do not blow the HOT right away, you likely will later.
Good Luck
Rick Nieman
Rick@niemandisplays.com
www.niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
TexasWalter
« Reply #3 on: August 30, 2007, 09:24:17 pm »
Thanks yall
What I have is a Blitz 99 with a bad mid res monitor chassis and a extra WG standard res in great condition but I guess I can not use the Standard in place of the mid so I am back to repair or replace the mid res.
Glad I asked before I tried and damaged the other monitor.
Thanks again
Walter
SirPeale
  • Green Mountain Man
« Reply #4 on: August 31, 2007, 01:18:43 pm »
a) fix your med res monitor
b) Blitz is standard/medium switchable.
