January 14, 2026, 10:35:53 am
I use a second sound card for the secondary output and it is unaffected by any of the volume controls.
The simple solution is split the audio feed before it goes into your amp.
With Randy's software, it doesn't appear to affect the strength of the output based on volume, just the actual sound.
Quote from: whammoed on August 26, 2007, 01:48:29 pmI use a second sound card for the secondary output and it is unaffected by any of the volume controls.So is it possible to use the onboard audio for one thing (output to light control) and then a pci sound card for the other (actual audio output) then?I'll have to play with Winamp a bit to see if it will work in conjunction with the music software I'm already running. (jukebox software actually)Is this the plug-in you are using?http://www.winamp.com/plugins/details/147344
