Author Topic: Donkey Kong (2-board) diagonal lines (fixed)  (Read 3056 times)
ncflagg
  • Last login:October 25, 2025, 08:49:13 pm
  • Oh, yeah. Idaho IS right next to Iowa.
« on: August 21, 2007, 04:13:54 am »
I didn't see a PCB repair forum so lemme know if there's a better place for this.
I'm trying to convert a Nintendo vs Unisystem back to a Donkey Kong. I have a 2 board version. When I turn it on I get the starup sound and some lines, mostly blue, that run diagonal like the horizontal position is way off. I read somewhere that the two vert horiz pots on the video board break often but mine seem to be ok. I can dial them in at 10k ohms. Could the eeproms be bad? How do I know that someone didn't put them in backwards or something?
« Last Edit: January 14, 2008, 02:10:57 am by ncflagg »
SirPeale
  • Green Mountain Man
Re: Donkey Kong (2-board) diagonal lines
« Reply #1 on: August 21, 2007, 07:45:39 am »
Pop us a picture.
ncflagg
« Reply #2 on: August 21, 2007, 12:57:26 pm »
The picture rolls/scrolls horizontally (lengthwise because I haven't turned the monitor yet) some of the time and sometimes it stops scrolling and I can see the the image changes to another screen but is still indecipherable.
SirPeale
« Reply #3 on: August 21, 2007, 01:41:09 pm »
When was this monitor capped last?
ncflagg
« Reply #4 on: August 22, 2007, 12:10:24 am »
This is a monitor I have just fixed. It had a bad Horizontal Output Transistor and I did a cap kit at the same time. The monitor runs two Nintendo vs Unsystem boards just fine (Golf and Excitebike). Currently, it has an old HOT from another monitor. I plan to replace it with a new one when they come in.
ncflagg
« Reply #5 on: August 24, 2007, 11:51:08 pm »
The monitor works fine. Any ideas?
Kevin Mullins
    • Me on Myspace
« Reply #6 on: August 25, 2007, 01:59:37 pm »
I would start off by verifying that you have the SYNC connected correctly for the DK boardset going to that particular monitor.
It MAY be different than the VS. games.
(not sure without looking at all the schematics and manuals myself)
It may also be a bad video output on the DK boardset.
If I remember correctly..... there should be a 50/60 hertz adjustment pot on the 20EZ, might try that.
ncflagg
« Reply #7 on: August 25, 2007, 11:29:41 pm »
I have tried hooking up to the 36pin connector and also by using a nintendo monitor cable direct to the board with the same results. Would I be able to determine if the video output is bad on the dk board by using a multimeter?
I looked at the manual for the Sanyo 20ezv and haven't seen a 50/60 hz pot. What does it do? Is it also called something else?
ncflagg
« Reply #8 on: January 06, 2008, 03:04:00 am »
Well, I pulled out the old DK 2-board pcb today and started testing some resistors and didn't find anything interesting. While shining my flashlight about I noticed on certain ICs there was a black residue almost like rust. The board was pretty dirty so I decided to take out a toothbrush and some water and scrub it down for 45 minutes. I put it back in my cab and  :applaud: I get picture! My sound quit working but I haven't done any testing on that yet. I'll work on it s'more tomorrow.  :cheers:
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
« Reply #9 on: January 06, 2008, 12:43:19 pm »
Check the two 30/60K pots on the VIDEO board (2nd board in the PCB set).
Best,
 - Mike -
ncflagg
« Reply #10 on: January 06, 2008, 04:48:25 pm »
1st post. Thanks, though.  :)
pcb
    • MikesArcade.com
« Reply #11 on: January 07, 2008, 12:44:10 pm »
So you got it working, eh?
Best,
 - Mike -
« Last Edit: January 07, 2008, 12:46:46 pm by pcb »
