Author Topic: Well Gardner 19" monitor only green  (Read 1436 times)
maroguy1
  • Last login:March 17, 2015, 02:00:05 pm
« on: August 19, 2007, 08:58:59 pm »
I have a wg 1196497.  Wondering what series monitor this is and will a cap kit repair it if the only color i get is green.  Should I also replace the transistors on the neck board will this work or is the tube shot.  I don't have another tube to try it on and I know it is the monitor.  THanks
Kevin Mullins
    • Me on Myspace
Re: Well Gardner 19" monitor only green
« Reply #1 on: August 19, 2007, 10:58:53 pm »
That serial number doesn't seem to be in Well Gardners databse. ( 1196497 )
Is it OVERLY green??
Really bright like it's almost too much green?
Try disconnecting the green input.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 20, 2007, 01:05:08 am »
And you looked here first:
http://forum.arcadecontrols.com/index.php?topic=62016.0
maroguy1
« Reply #3 on: August 20, 2007, 08:11:14 pm »
It looks like a 7000 series.  There is only green.  Even if i adjust to bring the other colors up they don't show up.  It looks like one of those old green monochrome monitors.  Thanks fellas!!
