Author Topic: Sanyo EZ (Nintendo, Donkey Kong) Monitor Question.  (Read 1427 times)
Neilyboy
  • Last login:November 09, 2024, 08:46:40 am
  • what day is it...
« on: August 12, 2007, 08:32:49 am »
Alright, so I am restoring a DK cabinet. I know the existing monitor (which I am 90% sure works) requires 100v. What I am trying to do is get away from using the existing (old bulky) nintendo power supply and was hoping to update the insides and get a new power supply and run a jamma setup much like what markrvp did in project announcements with his DK restore (http://forum.arcadecontrols.com/index.php?topic=51522.0).
Anyway, I guess what I am looking for is a little advice on what I should do. I would like to use the existing monitor (since its already inverted video and has the onboard audio board for the game). I would just like to update the power supply so it is not only safer but not so large and bulky.
I do know the marquee light also requires 100v but that is being switched out with a NovaMatrix 12v LED Marquee bar.
Thank you so much for any and all help you can offer.
Neil
Ken Layton
  • Guru
  • Technician
Re: Sanyo EZ (Nintendo, Donkey Kong) Monitor Question.
« Reply #1 on: August 12, 2007, 12:10:12 pm »
You will need a step down isolation transformer that outputs 100 volts. There are some that are made with two output taps you can select either 115 volts or 100 volts.
BobA
  • What Me Worry?
« Reply #2 on: August 12, 2007, 12:24:31 pm »
deleted:
« Last Edit: August 12, 2007, 12:28:08 pm by BobA »
Neilyboy
  • what day is it...
« Reply #3 on: August 12, 2007, 06:57:24 pm »
is it a smaller unit than the original nintendo power supply?
Neil
