Author Topic: More help with wiring up a steering wheel in MAME  (Read 2368 times)
scuzzie
  • Last login:November 28, 2008, 06:54:23 pm
« on: August 11, 2007, 12:37:53 pm »
Could someone help me identify what wire does what or goes where in the attached Steering Wheel Assembly.
It is a Midway Happ Controls Model 50-8593-00
The steering column has, I think, a pot at the end of it so I guess this makes it an anlogue wheel?? This has 3 wires coming from it, red, black and a yellow with a black stripe. The force feed back unit has a red and a black. Initially, I would just like to know how to connect the wheel up and ignore the forece feedback if this is possible.
I'm assuming that it somehow, (the 3 wires from the steering column), have to be wired to an A-Pac, (thanks pcolson and others), but what gets wired to where . . . .
Thanks to anyone who can shed some light on this problem . . . .
« Last Edit: August 11, 2007, 12:41:17 pm by scuzzie »
Paul Olson
    • Paul's Arcade
Re: More help with wiring up a steering wheel in MAME
« Reply #1 on: August 11, 2007, 04:56:10 pm »
The input wire is in the center. You can test which is ground using an multimeter, Dave has instructions http://dave.bit2000.com/ on his AKI wiring page. If you can tell which is which from the wires that are already there, then it's done.
Paul
scuzzie
« Reply #2 on: August 11, 2007, 08:18:07 pm »
thanks Paul for the elaboration on your earlier posts. . . I think I understand now
