Author Topic: help with my Jpac - arcade monitor, screen needs to be tracked.  (Read 1639 times)
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
I just got a die hard arcade cabinet and a jpac, I hooked it all up and can see my windows screen but its flying all over the place.
I am using soft15hz, which I assume is working because jpac prevents bootup unless its a safe signal.
On the back of the monitor there is a FOCUS and a SCREEN dial, one focuses and the screen dial seems to adjust brightness, Is there a control somewhere to track the picture possibly? Like an old vcr ?
Terminatedrone
  • Last login:April 07, 2011, 12:33:44 am
Re: help with my Jpac - arcade monitor, screen needs to be tracked.
« Reply #1 on: August 07, 2007, 01:20:17 pm »
Its not the screen or focus knobs you should adjust, look on the remote board for V-Hold and H-Hold and adjust those.
mrserv0n
« Reply #2 on: August 07, 2007, 01:24:01 pm »
oh thanks I see the board under the CP, ill try that now. Thanks again
