Author Topic: smart strip power strip powers everything on but does not do them off at once???  (Read 1200 times)
northerngames
  • Trade Count: (+18)
I have a smart strip hooked up and it power everything up with a single button but it does not power everything down but what is hooked to the control socket am I missing something here or do I need a larger model that supports that or something becuase having to go switch everything back off one after another kinda defeats the whole purpose of me having a use for this thing.
koolmoecraig
    • My Intervention
It takes a few seconds and then it shuts it all down.
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
The smartstrip has a adjustment pot that adjusts the sensitivity. Try turning the pot a few degrees and see if that makes the difference.
My old user name was marlborroman13, but I kicked the habit many years ago!
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
per the instructions:  Turn off the device that is plugged into the control outlet.  If some switched outlets don't turn off, turn the pot counterclockwise until the switched outlets turn off.  Turn on the control outlet device, and make sure the switch outlet devices come on.  If not, tweak it back clockwise.
