October 02, 2026, 02:58:43 pm
Make sure that the monitor is bolted down, and that everything inside not bolted down is removed.
Should be fine on its back. That's how I transported mine.
Indeed, mine was in the back of a van, but we had no problem with it. If you put an old sheet under it you can slide it out, and it will come out vertically, similar to what the Egyptians did for their obelisks.
