Author Topic: Go Time: how to build control panel (materials advice)  (Read 1779 times)
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« on: April 26, 2003, 01:00:05 pm »
I've got all Happs buttons and sticks, and I think a stick or two from Andy....
I've got 1/2" MDF and 3/4" MDF.
Which should I use for the control panel so I don thave to get funky with a router to do insets for joysticks, etc.
At first I was thinking I'll just do a Marble Contact Paper cover on the wood....maybe put Lexan on top of that if I can get HD to cut it to shape for me (can I just use a simple jigsaw to cut it??)...but now depth concerns me.
1/2" MDF with lexan on top, which will show smudges....or 3/4" MDF with no lexan and contact paper or paint on the CP...
".....its like a Koala crapped a rainbow in my brain!"
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
Re:Go Time: how to build control panel (materials advice)
« Reply #1 on: April 26, 2003, 11:27:56 pm »
You don't HAVE to route under the joysticks when you use 3/4" MDF.  My CP uses 3/4" MDF with 1/8" lexan on top and i didn't route underneath.  It's all a matter of preference.  If you want your sticks to be "long" then go with the thinner material or route.  It's just not necessary.  In fact, when i bought my used arcade cabinet the "real" control panel was made of 3/4" particle board with a graphic overlay and 1/8" lexan on it.  The underneath was NOT routed for joysticks.  This is how it was used in the arcade and that's good enough for me. :)
If you're really concerned about joystick height, use the 1/2".  Though, keep in mind that having your entire CP made of 1/2" material won't be nearly as strong.  You're going to NEED that lexan on there to help add some strength.
I personally would never use contact paper or paint on my CP.  Doing a graphics overlay covered by lexan just looks SOOOOO much better.  Sure, it shows smudges.  But it also cleans up very easily and adds a touch of class and professionalism to your cabinet.
paigeoliver
  • Awesome face!
« Reply #2 on: April 27, 2003, 12:25:37 am »
It depends on your joysticks. All my GOOD joysticks only work on metal panels due to short handles. But those cheesy happ sticks work on anything.
