Author Topic: Suzo/Wico 2 1/4" Trackball Mounting into Wood ?  (Read 3876 times)
webby
  • Last login:December 14, 2002, 02:01:04 pm
  • These damn wires !
« on: March 19, 2002, 08:28:51 am »
Hi,
Does anybody know how I can mount a Suzo/Wico 2 1/4" trackball into a wooden control panel. I checked the catalogues and they don't seem to sell mounting plates  :'(
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
Re: Suzo/Wico 2 1/4" Trackball Mounting into Wood
« Reply #1 on: March 19, 2002, 01:04:04 pm »
For the 3" you can use the happs mounting plates... So you can probably get the 2 1/4 happs mounting plates without a problem
webby
« Reply #2 on: March 19, 2002, 01:44:13 pm »
Ok thanks for that I was looking at the happ one for the 2 1/4". Maybe someone who owns one could let me if these dimensions are ok then :
The Suzo Trackballs screw points are 2 1/2" apart. The ball hole is 1 7/8" but the actuall raised point which will match the plate hole is 2 2/8"
Any info would be great
Cheers
Agent Davis
  • Last login:April 11, 2008, 04:14:41 pm
webby
« Reply #4 on: March 19, 2002, 04:40:49 pm »
Thanks for the link, however it doesn't show the actual size of the hole the raised cyclinder on the trackball needs to fit in. Nore does it show the spacings between the mounting holes on the trackball. If I can get these I will know if it will fit.
Im hoping that all trackballs (amusement ones anyway) use the same size hole and mount positions.
The Man
« Reply #5 on: March 20, 2002, 09:31:06 am »
I have a Wico 2/14 trackball with a Happ's mounting plate and it works great.
TM
webby
« Reply #6 on: March 20, 2002, 04:45:04 pm »
Great news :) Thanks for that I'll contact the UK branch of Happ and order one.
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #7 on: March 21, 2002, 10:41:02 am »
By the way, how can I order at Happ UK? I can't find a special website of them, do they accept orders via web?
Would be much easier for me, 'cause I need shipment to Germany. ???
webby
« Reply #8 on: March 22, 2002, 07:25:01 am »
> Happ Controls
> Unit 7, Hornet Close
> Pysons Industrial Estate
> Broadstairs, Kent
> Uk, CT10 2YD
> Tel:  +44 (0)1843 871100
> Fax: +44 (0)1843 871122
Carsten Carlos
« Reply #9 on: March 22, 2002, 09:08:08 am »
Thanx, webby!
Oh well, I fear that means I have to phone them? My english is just to bad to tell them on the phone what I need. (Maybe I should practise how to spell letters when they want my adress ;))
Well, maybe I should send them a telefax, that should make it somehow easier. Damned I haven't got a faxmodem anymore since DSL!
Do they have a printed catalogue, by the way?
