Author Topic: bought dvi > component and cable doesnt work...  (Read 1854 times)
DcMaN
  • Last login:March 17, 2020, 06:08:08 pm
« on: July 28, 2007, 01:59:43 pm »
hey whats up, i bought this cable hoping it would inrease the clarity to the screen, and it turns out that the cable doesnt work i cant get a solid picture. The computer has a geforce 7600gs pci xpress video card in the computer is ther anything  i can do ?
DcMaN
Re: bought dvi > component and cable doesnt work...
« Reply #1 on: July 28, 2007, 02:20:37 pm »
this is going to a tv that has 480i
Disturbed013
  • Last login:December 28, 2007, 08:18:14 pm
  • Anybody can be a non-drunk.
« Reply #2 on: July 28, 2007, 02:26:41 pm »
I think a little more info is needed here.
What do you mean by "solid picture"?  Are you getting nothing at all, only sometimes, partial picture?
Have you verified that the DVI on your video card works?  Hooked it up to a monitor with DVI input?  Does the TV have DVI and/or HDMI input?  Does the card have settings to tell it to use the DVI port?  Also, very likely, you need to change the input on the TV to disply signal from component input.  Does the TV work with other component video source?  DVD player?
Double Diamond  100%
Spy Hunter II  98%
Mame Cab ~65%
Jeff AMN
    • Gamer Theory
« Reply #3 on: July 28, 2007, 02:32:24 pm »
Some DVI to Component adapters are only compatible with certain cards. Mine only works with a handful of ATi cards. You might want to double check compatibility.
DcMaN
« Reply #4 on: July 28, 2007, 02:33:14 pm »
it just gets all scrambled and then turns to a solid blue line when i put it on the component input. Im 100% positive the inputs work on the tv, same goes for the dvi ports, i had a monitor hookd up to it previously i tried both dvi ports too. The tv does not have hdmi. Its actually a 6 foot cable, not the adapter.
f4phantomii
« Reply #5 on: July 28, 2007, 05:00:39 pm »
Couple of things here.....
DVI outputs vary a bit....there is DVI digital, DVI analog, and DVI that output both types of signals.
Your video card probably either outputs the combined analog/digital signal or digital only.  Check the specs on your video card.
If it outputs digital only, you'll need a converter box (which are very spendy) to do the conversion prior to connection to the analog component jacks on your TV.
If your video card does output an analog signal over the DVI, you may have to set the resolution very low so that the TV can sync the signal.
I tried for a couple of years to connect a PC to two different TV's for my mame cab.  I tried cards with TV-out options, going through RF modulators, etc.  I was never happy with the results (and the TV's weren't very pleased either!) so I settled for a PC monitor that I had sitting around.
Good Luck!
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #6 on: July 30, 2007, 12:45:13 pm »
Alot of 7600 series cards support component out without using DVI, they came with small break out boxes or cables.
Green Giant
« Reply #7 on: July 30, 2007, 01:33:15 pm »
Just to clarify, you did set your computer to 640x480 before hooking up the tv right?
A tv might not be HD, but having component inputs usually means it can handle 480i.
Does the cable that converts the dvi to component have any switches on it, are they set to 480i?
You say this is the 6ft cable, not the adapter.  Did you pick this up from monoprice, it still should have the adapter inside the cable.
Toxic Arcade, my first build
