Author Topic: question about grounds for my lights for my coin doors  (Read 1494 times)
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« on: July 25, 2007, 11:42:08 pm »
So tonite I got my coin doors to work - i drop in a quarter, system registers.  Fine and dandy.  Anyways, on the one coin door, each light has its own separate power wire and ground wire.  However on the other door it has just a single power wire that feeds both lights, and a single ground cable.  Now this ground cable is also the ground for the switches, or common i should say.  Would it hurt anything if I ran said wire as a ground, or should i just rewire the lights?
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
Re: question about grounds for my lights for my coin doors
« Reply #1 on: July 27, 2007, 02:08:26 pm »
Is this in a mame machine running a PC or an original cab?
If it's a mame/pc setup, I would separate the bulb ground from the coin switch ground.  The bulbs will run with a 12v dc power source and the ground from this power source will need to be isolated from the switch circuit. Not a good idea to send any stray voltages to your Ipac or Keywiz.
Green Giant
« Reply #2 on: July 27, 2007, 04:20:03 pm »
If the 12V is coming from your computer power supply you should be fine.  If this is a separate power supply, it could affect more than just the keywiz/ipac.  The safest bet is to isolate the 12V ground from the 5V ground though.
Toxic Arcade, my first build
lanman31337
« Reply #3 on: July 28, 2007, 10:42:55 pm »
Good call.  I'm just going to re-wire the lights and have a separate ground.  Thanks gents.
