Author Topic: How do I remove these bolts from the control panel  (Read 3111 times)
ryanhaws
  • Last login:August 17, 2007, 11:14:21 pm
« on: July 22, 2007, 05:47:45 pm »
I recently acquired a few arcade games but a couple of them have bolts on the control panel that I don't know how to remove.  Does anyone know that the name of the special tool is that I need to remove these?  See picture.  Thanks.
Kevin Mullins
    • Me on Myspace
Re: How do I remove these bolts from the control panel
« Reply #1 on: July 22, 2007, 05:52:10 pm »
You need a set of "security" bits.
Most hardware stores should have a small set of them that would work for those.
Example:
http://www.action-electronics.com/ezpower.htm
About the fourth set down opn that page would be a small set alot of places carry.
ryanhaws
« Reply #2 on: July 22, 2007, 06:17:28 pm »
Thank you so much!
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: July 22, 2007, 11:05:31 pm »
Amazingly enough a quality flathead screwdriver of the right size will fit right in there and work decently enough to get all but the most torqued security screw off...
dynamite
  • Last login:February 27, 2008, 05:08:18 am
  • let the games begin
« Reply #4 on: July 22, 2007, 11:18:50 pm »
or if you're lazy just open the control panel and undo the nuts under them. :dunno
bfauska
« Reply #5 on: July 23, 2007, 01:37:17 am »
Probably best to go with the appropriate security tip screwdriver, but since I've always enjoyed this story I'll pass it along here.  A friend of mine was doing some work installing or moving some signs on the walls inside of a prison, he had been assigned a helper from the residents of the prison and when he found that some signs had security screws he was going to come back the next day with the proper tools.  His helper informed him that if he heated the end of a toothbrush handle with a lighter and then pressed it into the security screw head he would make a custom plastic security driver for that style of screw.  I don't know if he did it or not, but the idea, and the fact that the convicts knew about it has always amused me.
severdhed
  • RIP Dinosaur Hippo
« Reply #6 on: July 23, 2007, 11:07:21 am »
i had some of them holding my marquee retainer in...nobody locally had the tools to remove them, so i put a reinforced cutting disk in my dremel and turned them into slotted screws.  worked like a charm and i didn't have to buy anything
knave
  • Last login:March 24, 2026, 03:52:12 pm
« Reply #7 on: July 23, 2007, 11:49:27 am »
I picked up a set of security bits for $2.99 at Harbor freight.  I've since used them quite a few times.  Plus it has some unique bit sizes that I didn't have before.
« Reply #8 on: July 23, 2007, 11:53:12 am »
That's a common way to do it in a pinch... most people will use a bic pen as the shaft.  Not really a prison specific task.  I've never had much luck with that method but it does work.
WunderCade
« Reply #9 on: July 23, 2007, 12:17:40 pm »
The convicts know about it because security screws are commonly use in jails/prisons.
« Reply #10 on: July 23, 2007, 12:19:31 pm »
Being a security screw is a good way to earn a solid pension.
bfauska
« Reply #11 on: July 23, 2007, 12:50:11 pm »
:laugh2:
It actually made me laugh, so I figured I had to give credit and reply.
« Reply #12 on: July 23, 2007, 12:51:53 pm »
Stare at that pic for a few seconds... I bet if you zoom out he really has a closeup pic of the Loch Ness Monster.
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #13 on: July 23, 2007, 06:54:51 pm »
Are u sure it's not a fish eye?
