Author Topic: OK Got My LED-Wiz Setup, Now What??  (Read 3583 times)
lettuce
  • Make It So!
« on: July 22, 2007, 11:04:30 am »
Setup my LED-Wiz and all LEDs are working first time (thank god), so now hat do i do?? What programs do i need to get the best out of the LED-Wiz, what can be done with the LED-Wiz?, i know Advanced MAME was the one that used the LED config, but i believe thats not in production anymore
buks
  • Last login:January 28, 2011, 06:43:25 pm
  • Squash the Sno-Bees !
    • Arcade Machine Construction
Re: OK Got My LED-Wiz Setup, Now What??
« Reply #1 on: July 22, 2007, 03:43:30 pm »
Depends on what O/S you are using but if its Windows then I can highly recommend Mala. Theres 2 ledwiz plugins available - I have only used "LEDWiz v2.0 by Edge and Loadman" and it works great. Very little setup needed.
mala homepage - http://mala.arcadezentrum.com/
Buks
lettuce
  • Make It So!
« Reply #2 on: July 22, 2007, 03:51:29 pm »
Yeah i was undecided on what Frontend to use out of, Maximus Arcade, AtomicFE, Mamewah, and MaLa. But knowing that MaLa supports LED setups, i think ive got to go with that really
buks
« Reply #3 on: July 22, 2007, 03:54:30 pm »
I was using MAMEWah but I had to also run a few "extra" bits and pieces to get the buttons flashing, so I switched to Mala. It was actually very easy to setup the emulators.
I *think* AtomicFE has ledwiz support too so hopefully someone else will post here with info.
Lots of mala support in the software forum here at byoac too !
Buks
MrScary
  • Last login:November 26, 2008, 07:28:41 am
    • Cronin's Custom Arcades
« Reply #4 on: July 22, 2007, 11:47:35 pm »
I haven't got mine yet (LED Wiz), but the already bad-ass front-end Game EX has a plugin built in for LED Wiz....check it out.. 8)
http://www.tomspeirs.com/gameex/
It is probably the best front-end out there and it is constantly updated with new functions and improvements... :notworthy:
"...the light at the end of the tunnel is another train..."
Dream Theater - 1997
lettuce
  • Make It So!
« Reply #5 on: July 23, 2007, 12:35:49 pm »
Looks a bit ugly really, and doesnt look that much different from Windows Media Center. But ill give it a go though
MrScary
« Reply #6 on: July 23, 2007, 05:52:19 pm »
You won't reget it....
That is just one of several themes.  It also includes a theme editor.....
I found it easier to configure than MameWAH, IMHO..
Green Giant
« Reply #7 on: July 25, 2007, 11:28:03 am »
Not sure what else you have looked at, but Mala can do just about everything you could want and probably much more.  I am not sure about the LED support functions for Gameex, but MALA has some amazing features.
I am using the ledblinky plugin with my ledwiz.  It is amazing because it shows the actual button configuration in the actual colors from the original game.  Then when you start a game it flashes the button and speaks the action.  You get that and every other feature all for free.
I have some videos showing the buttons on the thread about my cab.
Toxic Arcade, my first build
