Author Topic: First compile, please help!!  (Read 1408 times)
vettetekk
  • Last login:June 20, 2009, 05:06:08 pm
« on: July 21, 2007, 09:40:00 pm »
Ok, Ive read a bunch of posts of teaching a man to fish and so on. So before asking for a compiled version of mame I figure Id try it out. Following Mr. Dos compiling instructions, I made it all the way down to the patchmame.bat part. When I did that, I go t a readout saying hunk # 2 failed at 980. I have no clue now if I should compile mame or not.
Im trying to add the latest hiscore.diff file as found in this thread:
http://forum.arcadecontrols.com/index.php?topic=64298.0
Apparently MKChamp had added the .117 hiscore. text. Im a little confused at how to apply this file. Do I rename it to a diff file or what. Im sure this is where my error is.
Thanks for listining!!
~V
PS - if anyone does have a precompiled 117 - send it too me  ;) ;D
vettetekk
Re: First compile, please help!!
« Reply #1 on: July 21, 2007, 10:18:31 pm »
ok, I went ahead and found out that I had to apply the latest .diff patch then the .txt file. So I got that done with no errors, but after 15 minutes into the compiling, it stopped and gave me an error (see attached pic). so now I have no Idea where to go.
Please Help!!!
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
« Reply #2 on: July 22, 2007, 02:34:30 am »
If you are using the 117 source, then you need to use the hi_116u4 file. If you plan on compiling 117u1, then the order would be to patch the 117 source with the 117u1 diff and then patch with the hi_117u1 diff.
Also, it would be a good idea to do a clean compile. To be safe, delete everything and start over. Good luck!
vettetekk
« Reply #3 on: July 22, 2007, 12:51:24 pm »
Thanks for the reply!! It took some doing, but I had a sucessful recompile this morning!! I guess I can eat now that I know how to fish!!! :laugh2:
~V
