Author Topic: arcade controls to megadrive  (Read 2049 times)
thunder-rolling
  • Last login:August 25, 2007, 06:23:47 pm
« on: July 09, 2007, 05:56:47 pm »
Hi,
The sega megadrive machine stills gets a lot of play here. I got the idea of wiring some arcade controls to it.
What would be the best way to go about this? Hack a megadrive controller? Does anyone have any experience with this?
Hurray Banana
  • Last login:October 18, 2016, 02:11:08 pm
  • My unique teaching style
Re: arcade controls to megadrive
« Reply #1 on: July 10, 2007, 10:35:48 am »
Hacking is reasonably straightforward as you long as you are ok soldering.
Luckily old pads aren't hard to find which is good as you may end up cocking up a few while you practice.
I've hacked PS2, Saturn and Dreamcast pads to use the machines in my machine. Make sure you secure the cables with something like hot glue from a glue gun. This will relieve the strain from the solder joints.
Cheers Eric
TZ Pinball, PowerDrift upright, 4 vertical Mame cab and 8 way 2 player Mame cab
