Author Topic: Need help with power supplies  (Read 1320 times)
SLICK19
  • Last login:September 08, 2024, 09:33:50 pm
  • GET LOST PUNK !
« on: July 02, 2007, 02:55:56 pm »
Hey guys,
I need some help regarding a power supply. I am in the process of rounding up the parts for a arcade game I want to restore and I ran across a manual for my game that states the power requirements. Here is what it printed....
" Be sure the power supply from your old game is capable of +5 vdc regulated at 6a; +12 vdc regulated at 1a and -5 vdc regulated at 1/2a"
What should I use?
 I understand this is probably a dumb question, but I don't want to buy the wrong thing and  BBQ the pcb. Besides, I am new to this.... cut me some slack.
Any help or advice will be greatly appreciated. Thanks.
RandyT
  • Last login:June 09, 2026, 12:58:21 pm
    • GroovyGameGear.com
Re: Need help with power supplies
« Reply #1 on: July 02, 2007, 03:02:55 pm »
Seems like a standard ATX style supply should deliver all of that.  But you'll need to hardwire the "power good" line to an adjacent ground to get it started.
RandyT
Rocky
« Reply #2 on: July 03, 2007, 08:21:16 am »
Power supplies (both computer and arcade) list the amperage rating for the different voltages.
Make sure that the power supply you buy has at least the amperage rating listed in your game manual.  It's okay if the power supply is rated higher.  It's a listing of the maximum draw it can handle.
Good luck,
Rocky
SLICK19
  • GET LOST PUNK !
« Reply #3 on: July 03, 2007, 03:41:12 pm »
Thanks Rocky,
That is what I need to know. After reading the game manual I was wondering if it took a particular power supply. I read somewhere once that a lot of game manufacturers had power supplies designed specifically for one game and then another for a different game. The article mentioned that this took place back in the days before the switching power supply made an appearance.   ;D
