Author Topic: Marquee cleaning?  (Read 1248 times)
cowguy
  • Last login:August 08, 2011, 01:07:41 pm
  • an 80s child in spirit
Marquee cleaning?
« on: June 20, 2007, 12:05:18 am »
I got some finger prints on my marquee, and tried putting a tad bit on water and made it worse! Is there any way to clean them?  I really don't want order a new one, my dad will be pissed.
dcsipe
  • Last login:November 09, 2015, 08:45:36 pm
Re: Marquee cleaning?
« Reply #1 on: June 20, 2007, 12:25:22 am »
Did you try using something like a screen cleaning wipe?  Or maybe one of those microfiber cloths that come with sunglasses?
bfauska
« Reply #2 on: June 25, 2007, 05:36:33 pm »
Are the fingerprints on the artwork itself or the plastic cover.  If the prints are on the acrylic in front of the marquee, or the marquee is printed directly on plastic and the prints are on the side w/o the art you should be able to use an acrylic cleaner.  We use a product at work called brilliantize, although I can't seem to find much info online about it.  Do a search for acrylic cleaner and you should get some usefull results on Google.  It is also useful if you have any acrylic on your CP or for your Bezel.  Some products used for glass are bad for plastics and others leave lots of static, most acrylic cleaners are supposed to cut the static and not harm the plastic.
Good luck.
