Author Topic: coin door question  (Read 2912 times)
Trebeck
  • "The Arcade" - Build #4
coin door question
« on: June 18, 2007, 06:39:16 pm »
Hey all
Well, after a year I have decided to get my coin door working (finally).  Well it's a new door that I got from Happ:
http://www.happcontrols.com/coindoors/40003800.htm
And it's in perfect working order.  The only thing is I don't know how to work the damn thing.  When I put in a Canadian quarter it hangs in the middle piece and wont come out until you press in the return lever.  So basically it doesn't come through.  Does anyone have instructions for the doors or better yet an easy fix?
Such a newb  ???
Beck
Kevin Mullins
    • Me on Myspace
Re: coin door question
« Reply #1 on: June 18, 2007, 07:25:40 pm »
Which coin "mech" did you get with it ?
Optional Equipment:
# Coin meter 4.5 VDC or 12 VDC
# Custom wire harness
# Foreign and token coin mechs
# Steel security bar available.
# Replacement Upper Door assembly for Convertible Coin/Currency Door System
# Fitted with $.25 U.S. Coin Mech
SirPeale
  • Green Mountain Man
« Reply #2 on: June 18, 2007, 08:29:38 pm »
Canadian quarters are magnetic, so they're getting caught on the magnet inside the mech.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: June 18, 2007, 08:32:22 pm »
Yep ... just unscrew the magnet bracket and remove the magnets.
Working: Not Enough
Projects: Too Many
Progress: None
PsychoAU
  • Last login:October 04, 2020, 12:27:19 am
« Reply #4 on: June 18, 2007, 08:37:43 pm »
I don't mean to hijack your thread, but I have a coin door question, too...  On the attached pic, I drew two white arrows on the left side.  What do these parts do?
SirPeale
« Reply #5 on: June 18, 2007, 08:48:02 pm »
One is a lockout coil, it makes it so you can't put coins in the machine when it's off.
The other is a slam switch.
Kevin Mullins
    • Me on Myspace
« Reply #6 on: June 18, 2007, 09:15:49 pm »
So are the Canadian quarters the same diameter as the US quarter ?
Ken Layton
  • Guru
  • Technician
« Reply #7 on: June 19, 2007, 12:29:39 am »
No, Canadian quarters are smaller in diameter than USA quarters.
Kevin Mullins
    • Me on Myspace
« Reply #8 on: June 19, 2007, 12:40:59 am »
Thanks for the clarification Ken.
So someone would defineately need the right coin mech to begin with.
Happ #42-3054-00     $.25 Canadian Coin Mech
« Last Edit: June 19, 2007, 12:48:30 am by Kevin Mullins »
CheffoJeffo
« Reply #9 on: June 19, 2007, 06:58:39 am »
Canadian collectors use Happ US mechs regularly -- they work fine after removing the magnets (20+ US mechs for me so far).
The difference in diameter between US and Canadian quarters is less than half a millimeter.
If ordering new, I would tell a Canadian to order Canadian mechs. If he already has the US mech (or comes across a great deal on US mechs), remove the magnets.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #10 on: June 19, 2007, 08:05:27 am »
Maybe you can use US quarters as tokens . . .
'bout all there worth these days  :laugh2:
Kevin Mullins
    • Me on Myspace
« Reply #11 on: June 19, 2007, 08:36:32 am »
Thanks CheffoJeffo - I like learning those odd little tid-bits, good to know stuff.
I'm not gonna disagree with that one...........
CheffoJeffo
« Reply #12 on: June 19, 2007, 09:15:43 am »
Just passing along what the good folks up here have taught me.
It makes life easier because it is tough to find a killer deal on Canadian mechs, but I've found lots of US mechs for $1 or less each (so if anybody want some magnets from US mechs, I have 'em).
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
Trebeck
« Reply #13 on: June 20, 2007, 12:00:00 pm »
Hey guys thanks for the help.  If all I have to do is remove some magnets then that's great.  But if I had to buy a new mech....
Canadian quarters are magnetic.  That might help me win the next game of Trivial Pursuit!
Beck
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #14 on: June 20, 2007, 06:03:11 pm »
I hope you realize he's speaking of the magnets in the mech, not the electro-magnet that is known as a "lock out coil". Removing that would be bad.
NO MORE!!
siddhartha
  • Last login:October 24, 2007, 01:09:37 am
« Reply #15 on: June 20, 2007, 07:45:21 pm »
I had the same problem with the same coin door, but using two Canadian mechs. One would let the quarter pass, the other wouldn't and would get hung up on the sizing piece of metal that rotates (the 'cradle'). The piece looks like a brass arm. Anyway, I simply filed down the piece that contact the quarter a bit and now everything works fine.
Trebeck
« Reply #16 on: July 02, 2007, 09:32:38 pm »
hmm OK I removed the magnet (thick square block) and now the coins go through to the return slot and not go through as if they were accepted.  I'm not sure why but I haven't spent too much time on it so I'll try tomorrow night to see if I can get t going. If I can't then I'll take some pics and post em.
Beck
SavannahLion
« Reply #17 on: July 02, 2007, 10:21:18 pm »
Stupid question. What's a slam switch?
