Author Topic: NESVS control to PC Help!  (Read 1603 times)
chuggy
  • Last login:December 12, 2004, 11:37:49 pm
« on: April 20, 2003, 08:20:50 pm »
OK
This has been quit the productive day so far. I have decided to go away from the console, and use a pc. The monitor wiring seems very well documented, but im having a problem finding control instructions. I have a Nintendo VS control panel. can anyone help?
bloodyviking77
  • Last login:March 07, 2010, 07:01:38 am
Re:NESVS control to PC Help!
« Reply #1 on: April 20, 2003, 09:27:09 pm »
Hey there,
If you're going to be interfacing the control panel to a pc, you need to convert the button presses into signals the pc can understand.
There's a heap of ways to do this, from hacking a keyboard (not as hard as it sounds) or a gamepad/joystick (even easier), to buying a special "keyboard encoder" designed specifically for the purpose.
There are pros and cons of each, with the biggest "pro" of hacking a keyboard or gamepad being extreme cheapness!
Best place to start is to look over to your left and click on "interfaces".
My advice, if you have the patience but little in the way of funding, is to read the keyboard hack guides carefully and give this a go.
the IPAC from Andy www.ultimarc.com is ace if you can afford it though!  ;D
Shut up! Bloody Vikings!!
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #2 on: April 20, 2003, 09:58:15 pm »
ultimarc is a great resource/products...
but may I just point out  that the keywiz is a cheap keyboard encoder  (I only bring it up as the O.P. mentioned being a destitute college student...)
good luck with your project...
rampy
chuggy
« Reply #3 on: April 20, 2003, 11:48:33 pm »
I did find the KEYwiz websight, and 26 bucks fits any budget. Have you used this before, and is it an easy way of doing this? thanks for your other responses.
rampy
  • *shrug*
« Reply #4 on: April 21, 2003, 09:08:03 am »
I've used the middle tier one (the one with the terminal barrier thingie)... and am pretty darn happy with it... It's much easier/better than my sidewinder hack that was in there previously.
THe cheapest key wiz does require some very rudimentary soldering though (there's no barrier strip/screw terminal thingie)
But if you were considering a keyboard hack or a gamepad hack, you'd be soldering anyways...
Rampy
SirPeale
  • Green Mountain Man
« Reply #5 on: April 21, 2003, 11:01:21 am »
Save yourself some agrivation.  Buy the standard model.  For seven bucks more, you can't beat it.
chuggy
« Reply #6 on: April 21, 2003, 01:25:54 pm »
cool will do
thanks again
