Author Topic: problem - no display with 19" vision pro  (Read 1857 times)
lowlifefalcon
  • Last login:July 12, 2009, 08:09:39 pm
« on: June 07, 2007, 09:56:09 pm »
i got a vision pro mtg-1902en for a Mame project, it has a vga input on the monitor it self. When i hook it up to any motherboard/and video card all the monitor says "Check SIGNAL INPUT" ... what am i missing on this, will it not work with a normal video card?
 It was bought from Happ controls a while ago and just got around to checking it out.
SirPeale
  • Green Mountain Man
Re: problem - no display with 19" vision pro
« Reply #1 on: June 16, 2007, 06:53:53 am »
I tried searching for this monitor and couldn't find it.  But from your description it sounds like it's not getting a correct video signal.  Are you trying to feed it a 15KHz signal?
This happens with *any* video card?
lowlifefalcon
« Reply #2 on: June 16, 2007, 12:30:25 pm »
i used a regular video card, 4 different ones. I emailed the info to marc at ultimarc and he said the specs look like a regular monitor and should have worked. If i can find someone in chicago that has a arcadevga card i will that a try. when i get back i will post the specs of the monitor here so people can see it and tell me what they think. funny thing is i searched for it to and cant find any info on it either.
I will look at the box and see if there is anything on there.
Thanks for the help
grantspain
« Reply #3 on: June 16, 2007, 03:00:10 pm »
according to the happ site thats a 19inch vga/svga monitor so it should work fine with a standard vga card
Kevin Mullins
    • Me on Myspace
« Reply #4 on: June 16, 2007, 03:34:23 pm »
But is it also CGA compatible ?
If so, is it "selectable" or "automatic" as far as video input is concerned ?
grantspain
« Reply #5 on: June 16, 2007, 04:05:12 pm »
according to the happ site its only vga
