Author Topic: Mitsubishi Megaview XC 3315C Should I consider it?  (Read 3258 times)
MajorHavoc
  • Last login:December 04, 2015, 09:08:40 am
« on: June 03, 2007, 08:03:01 am »
I've got a line on a Megeview 3315C.  He's asking about $100.00 for it.  I'm going to probably look it over tomorrow.  Since this monitor supports S-Video, would I get a decent results with using my tv out capability or will the signal suffer from the fuzzies?  Any info from anyone using one of these would be appreciated.  I like the size but if I'm going to be stuck with a white elephant......well, you get the picture.
TIA
Mike
shorthair
Re: Mitsubishi Megaview XC 3315C Should I consider it?
« Reply #1 on: June 03, 2007, 05:46:16 pm »
If it has vga input, screw the S-video. Even more so, is it a multi-sync?  If either is, let alone both are, yes - hell yeah get it.
MajorHavoc
« Reply #2 on: June 03, 2007, 09:53:17 pm »
According to the info I was able to dig up online, the monitor has BNC, MAC 15 pin, composite and s-video inputs.  The monitor is multisynch/multiscan.  I'm going to go take a look at it tomorrow and try it out with my laptop which has s-vid out.
tetsu96
  • Last login:September 06, 2024, 12:00:03 pm
  • MAME On...
    • My Old Cabinet / MAME32 build site
« Reply #3 on: June 03, 2007, 10:52:18 pm »
Those are pretty good for MAME I'd think.  I've got a 3715C which is the larger version, and the scan range was about 15-38 KHz horizontally if I recall.  Works great for AdvanceMAME, and as a bonus, this is one of few large monitors that can do interlaced video at 15KHz which is a nice value add if you have a Dreamcast and want to use the hacked 15KHz instead of VGA for games.
On a side note, I've never gotten the MAC input to display video from a PC or Dreamcast.  Shouldn't a PC -> MAC monitor adapter be enough for compatibility or is something screwy about the MAC VGA connection?
shorthair
« Reply #4 on: June 04, 2007, 04:06:49 pm »
Here you go: http://www.angrymods.com/mame/mitsu.htm
Testu: I'd think you'd probly know more than most but I'm guessing since it doesn't there must be some sort of identifier component in the signal a mac sends.
MajorHavoc
« Reply #5 on: June 04, 2007, 09:59:43 pm »
I went, I saw, I purchased!      ;D
Hooked the thing up to my laptop and immediately fell in love.
WOW! it's big
and
Heavy!!
Can't wait 'til I can give it a go with Golden Tee.
shorthair
« Reply #6 on: June 04, 2007, 11:44:23 pm »
Good deal, in more than one way.
