Author Topic: Happ Super Joy Stick Questions  (Read 2254 times)
cowguy
  • Last login:August 08, 2011, 01:07:41 pm
  • an 80s child in spirit
« on: June 03, 2007, 01:31:26 am »
I have some happ joysticks and I have a problem,  when iI turn the joystick it can't reach far enough to hit the micro switch.  I have to put a piece of paper in between the metal arm and micro switch so it will be triggered.  Is there anything I can do to adjust this?  Also the actual stick seems to be kind of short, does any one sell long shafts?
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
Re: Happ Super Joy Stick Questions
« Reply #1 on: June 03, 2007, 03:05:21 am »
If they are in fact Supers, you can always bend the little metal levers that press the microswitches outward/inward.
And Supers alos have an adjustable shaft length according to Happs ad copy. See if yours is set to the sort length, and adjust as necessary.
cowguy
« Reply #2 on: June 03, 2007, 01:18:48 pm »
I have them set to be long, but the whole stick that comes out is only about 2 inches tall.
Joystick Jerk
« Reply #3 on: June 03, 2007, 01:40:02 pm »
I assume you're mounting in a wood panel. Did you recess the stick when you mounted it?
And if you want longer shafts, just check out some of the dealers on the Buy/Sell subforum. A few of them carry long joy shafts, if I remember correctly.
cowguy
« Reply #4 on: June 03, 2007, 01:58:30 pm »
I am using a cardboard box right now so I can learn how to some of this before I go to wood, and what do you mean by recess?
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #5 on: June 03, 2007, 02:42:03 pm »
To recess a stick you'd rout some material away from where the stick sits. See the attached pictures.
Do you have this problem when the sticks aren't mounted in anything? A cardboard box  shouldn't alter the throw of the stick. I'm thinking maybe you have the joystick assembled incorrectly? See the exploded view of your stick from the manufacturer's website.
stuckpixel
  • Last login:March 15, 2016, 02:59:23 pm
« Reply #6 on: June 03, 2007, 02:43:34 pm »
I'd tend to agree with scotthh, cardboard is too thin to really have an effect on the joystick throw. Maybe you could post a pic of how you have it assembled?
cowguy
« Reply #7 on: June 03, 2007, 07:11:47 pm »
Here are some pics
Joystick Jerk
« Reply #8 on: June 03, 2007, 08:06:55 pm »
That height is about right for a Super. You can of course get a longer shaft if you want, but honestly, most modern arcade games have shafts as long the one in your picture.
cowguy
« Reply #9 on: June 03, 2007, 08:28:45 pm »
My hand just feels kinda cramped, I swear your average arcade sticks were longer.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #10 on: June 03, 2007, 09:23:26 pm »
It's hard to see in those pics, but I think you have your actuator on upside down.  That's why you're having trouble tripping the switches.
Joystick Jerk
« Reply #11 on: June 03, 2007, 11:26:32 pm »
Some definitely were. A lot more of the older ball tops had longer shafts. The more modern bat handle joysticks tended to have short shafts. Bat handled sticks really came on the scene with modern fighters, and you want a quick stick with short throw to pull off those quick fighting moves.
