Author Topic: Attatching Glass to an Upright Cab?  (Read 1628 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: April 18, 2003, 01:35:33 pm »
What is the best way to install the glass on a LUSID type cab? I would like to be able to remove it without too much trouble, should I need to adjust the monitor, etc...
OSCAR
    • Oscar Controls
Re:Attatching Glass to an Upright Cab?
« Reply #1 on: April 18, 2003, 01:44:40 pm »
See this thread:  http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=4057;start=0.  This method may be a bit tricky to do with a LuSiD design because of the separte control panel, but it might give you some ideas.
In that thread is linked another thread which discussed this as well.
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
« Reply #2 on: April 18, 2003, 05:10:11 pm »
I took the easy route, a glass drill bit and drilled a hole through each corner of the glass. then put screws through it into my bezel. I have these little black things that I got from the home depot that cover the screws. My bezel pulls right out so for me it's really easy to remove.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #3 on: April 18, 2003, 05:15:02 pm »
Pictures!!!  I'd like to see how you did this.
Best Kid iPad Apps
SNAAAKE
  • -Banned-
« Reply #4 on: April 19, 2003, 01:37:32 am »
Well here is one if it helps... :)
I took the easy way around as well.
I got the idea from Scott's unicade.
http://home.austin.rr.com/shumate/unicade/
« Last Edit: April 19, 2003, 01:38:20 am by SNAAAKE »
