Author Topic: Best kind of saw?  (Read 4158 times)
dndcollect
  • Last login:September 18, 2007, 09:09:54 pm
Best kind of saw?
« on: May 28, 2007, 08:31:29 pm »
if a table saw is not an option, would a jig saw or circular saw be the best option?
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
Re: Best kind of saw?
« Reply #1 on: May 28, 2007, 08:38:18 pm »
Straight cuts: Circular saw
Curved cuts: Jig saw
You'll need both.
It's 9am. I'm calling it a nite.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #2 on: May 28, 2007, 10:34:54 pm »
can't make curved cuts with a tablesaw anyway...
so a wormdrive circular saw is my answer...-=)
NiteWalker
« Reply #3 on: May 28, 2007, 10:36:59 pm »
As nice as worm drive circular saws are, they're overkill for hobbiest use. I don't think worm drives can cut curves either...
bfauska
« Reply #4 on: May 28, 2007, 11:12:37 pm »
I can cut a real nice circle with a table saw, and huge even curves with a circular saw, but nothing you'd want to use on an arcade cabinet.
The Porter Cable SawBoss is a great little saw, even with it's little blade it can cut through 2x material at a 45 degree angle, and it's light enough to handle all day long with no worries.
And don't forget to check out This thread.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #5 on: May 29, 2007, 11:33:35 am »
Just remember: if you buy a saw that uses a 6-inch blade, you'll never be able to find replacement blades locally and you'll always have to order them. For that reason alone, I'd buy a saw that uses a standard 7.25" blade...
bfauska
« Reply #6 on: May 29, 2007, 10:34:21 pm »
Keep 2 blades on hand when 1 gets dull take it to a sharpener and use the other, when one gets it's last sharpening order another.  If you aren't sharpening blades you are wasting money.
NiteWalker
« Reply #7 on: May 29, 2007, 11:28:28 pm »
For the price of decent circular blades being generally under $10 it's not worth the money to sharpen them...
10" tablesaw blades are a different story though.
I've dont the tablesaw method of making circles; IMHO it puts too much lateral stress on the blades. The same setup can be used on a bandsaw with great success. I generally prefer a router trammel arm though. Super clean precise cuts.
The sawboss is a nice little saw, but I think it's overpriced. A full sized circ saw of excellent quality can be had for less.
bfauska
« Reply #8 on: May 30, 2007, 02:19:17 am »
If you make enough straight passes at the table saw with about a 2 degree pivot between cuts you can cut away most of the circle before starting to spin near the blade.
I suppose I was thinking more about larger blades with the sharpening comment, I haven't had to find a blade for the sawbosses in any of the shops I work at, I imagine in a good sized city it wouldn't be that hard.  I know all of the shops we have our stuff sharpened at can get just about any blade we can dream up in a pretty quick time.
The price on the Sawboss is a drawback, but I tend to move 2 or 3 other circular saws out of the way in any shop that has one so that I can get to it and use it.  The size and weight are really nice.  I suppose my original suggestion may be foolish since I was thinking about the amount of saw somebody would need for hobby use and not the amount of money somebody would want to pay for a hobby use saw.  Those things are clearly in opposition when comparing the Sawboss to a more standard circular saw......
I'm still going to get one soon.
NiteWalker
« Reply #9 on: May 30, 2007, 08:33:23 am »
I do like the fact that it's only 9 amps instead of the normal 15. No poppin breakers...
