Author Topic: Mamewah question  (Read 1630 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
Mamewah question
« on: May 24, 2007, 09:26:36 am »
Hi guys I have a question about Mamewah because I am using an arcade monitor I have set my mame resolution to  640x288 and this has been done in my Mame ini file.
If I am making a Mamewah background will I need to make it the same size 640x288 and will I need to change my mamewah ini file this resolution or can two different resolutions be used.
That being one for mame games and one for the mamewah screen?
Hope this makes sense I have waffled on.
Zebidee
  • Trade Count: (+9)
  • Last login:Yesterday at 10:04:09 pm
Re: Mamewah question
« Reply #1 on: May 24, 2007, 06:09:30 pm »
Hey Mark,  I don't think that you need to edit any .ini files.
Just use the MameWAH Layout Designer (should be in your Mamewah directory) to edit the "layout.lay".  Edit your layouts so that the size is 640x288 (do this from the menu, Background -> size -> 640 -> 288).  This is how Mamewah determines the res to use for each emulator.
For Layout.lay, MameWAH 1.62+ first looks for this file in your config directories (eg mamewah\config\mame, mamewah\config\daphne), and after that in the mamewah\config directory.
You'll either need to use the default Mamewah layout (simple enough), which doesn't have a background image, or make up some 640x288 background images for your emulators (more work than it sounds!).  Use the same resolution for all your emulators, it will ease the pain later.
cheers, zeb
Marky_1979
    • Personal Webspace
« Reply #2 on: May 29, 2007, 10:39:34 am »
Thanks again Zeb
