Author Topic: Product Idea for Someone (Templates)  (Read 7335 times)
2600
« on: May 24, 2007, 09:24:20 am »
I'm not signing up for it, but I've been thinking that it would be a good idea for someone to make a few templates to sell here.  A joystick and a couple different button templates would cover a lot of control panels.
Any thoughts?
Anyone want to sign up for it?
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
Re: Product Idea for Someone (Templates)
« Reply #1 on: May 24, 2007, 11:29:55 am »
Definitely doable. I'm gonna look into it a bit more.
It's 9am. I'm calling it a nite.
« Reply #2 on: May 24, 2007, 11:31:15 am »
Trackball and spinner jigs would be good.
Chris G
« Reply #3 on: May 24, 2007, 12:00:53 pm »
What would a spinner jig be for?  Are there spinners that require more than just a button hole cutout?
« Reply #4 on: May 24, 2007, 12:02:41 pm »
Don't know, never installed a spinner, I assumed it needed a routed spot.
2600
« Reply #5 on: May 24, 2007, 12:18:24 pm »
Trackball is a good idea, hadn't thought about that.  Although, which side are you talking about.  I could use one for the top side.
FYI, the spinner is just a button hole.  Most of them have it so the axle(?) can be raised up and down for different height control panels so no need to route anything.
2600
« Reply #6 on: May 24, 2007, 12:29:55 pm »
Sounds good.  I've seen some of your templates and they are small and thin enough that I'd assume that shipping won't be a big PIA.
FYI, if templates are made and sold.  I was also thinking that we can scan and put them in a pdf or whatever is necessary so that people can use those templates when designing artwork.
  • Last login:Yesterday at 12:18:13 pm
« Reply #7 on: May 24, 2007, 02:11:24 pm »
Corner templates of varying radii would be great for CP tops.
miles2912
« Reply #8 on: May 24, 2007, 07:50:56 pm »
I used these for my CP
http://webpages.charter.net/rbecker5/files.html
Worked fine.
NiteWalker
« Reply #9 on: May 26, 2007, 09:22:15 pm »
Miles, I think 2600 meant templates to use with a router.
Donkey_Kong
    • CNC Machines
« Reply #10 on: May 27, 2007, 12:12:18 am »
It took me forever to figure out the diameters for a jig on a trackball mount. I routered from the bottom to within 1/4" & then made a jig for the top 2-7/8" round hole for the ball. I used cardboard. Needed it to be really close to perfect as there will be no CPO, just stained wood.
Happy to say I survived.
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
« Reply #11 on: June 01, 2007, 03:07:02 pm »
I'm not too familiar with router templates, but wouldn't it be specific to the brand/model router you are using?  Not including ones made for use with edge bits of course.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #12 on: June 02, 2007, 09:03:32 pm »
absolutely not...
for curiosity's sake...what makes you think that it would...?
« Reply #13 on: June 03, 2007, 10:41:12 am »
I'm guessing different base offsets for different models.
miles2912
« Reply #14 on: June 03, 2007, 03:28:47 pm »
If you are using a pattern bit to cut out the holes then templates are doable.  I used a generic cutting bit and therefore had to know how far in my router cut.  I then traced the outline of the TB and clamped a straight edge out the distance my router cut.  I had to reclamp 4 times but it worked out fine.
So you can see how knowing how far in a certain brand/model cuts is important.
2600
« Reply #15 on: June 03, 2007, 08:14:00 pm »
Yes, I was talking about router templates.  I was assuming that pattern bits would be the easiest way to go.
Dustin Mustangs
  • Cut the sheet!
    • My Site
« Reply #16 on: June 04, 2007, 07:55:06 am »
Yeah, the difference in offsets that chad mentioned was what I was thinking of.  The way I understand it, you have no choice but to deal with those when making a mill (ie a recess for a tb or joy mounting plate).  I imagine those would be the types of cuts that a template would be of the most help.
If you where using just pattern bits I guess you'd just be limited to cuts that go all the way throught the board?
« Reply #17 on: June 04, 2007, 09:07:41 am »
Wouldn't a plunge router be fine for that?  You would have to find a way to support the router base, though, and securely attach the template in place at the same time?
Dustin Mustangs
  • Cut the sheet!
    • My Site
« Reply #18 on: June 06, 2007, 12:35:03 pm »
Right, but now you're away from edge bits and the possibility of a 'universal' template that will work with any router.  Unless I am missing something...
« Reply #19 on: June 06, 2007, 12:37:39 pm »
I think I am too.  There are many different concepts here.
