Author Topic: What router bits do I need for cabinet making?  (Read 3887 times)
Spyridon
« on: May 21, 2007, 12:08:57 pm »
Just picked up my first router.  I know I need a slot bit for the t-molding, but what else do I need for basic cab building?  I will be recessing my joysticks, but I'm not sure what type of bit to use for that.
lordtodd75
  • Last login:July 21, 2020, 01:42:37 am
  • I especially hate punks!
Re: What router bits do I need for cabinet making?
« Reply #1 on: May 21, 2007, 12:27:43 pm »
A pattern flush trim bit should work well for that. It is also useful for cutting button/joystick holes in lexan if you plan on having a protective overlay for your CP.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #2 on: May 21, 2007, 02:42:08 pm »
Typically, I think you'd use a straight or spiral bit to create the recess necessary for a joystick... Given that a flush trim bit only cuts from the side and has a bearing on the bottom, I'm not sure how you'd use it to create a recess.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #3 on: May 21, 2007, 05:40:00 pm »
what about a pattern bit that has the bearing on the top...?!
Chris G
« Reply #4 on: May 21, 2007, 08:46:13 pm »
Maybe this one needs to be sticky'd or wiki'd...
Click Me
lordtodd75
« Reply #5 on: May 22, 2007, 01:48:48 pm »
hmmm. My pattern flush trim bit cuts from the bottom, maybe you are thinking of something different? You could use a straight but isnt the pattern flush trim bit a straight bit with a bearing at the top.
ScottS
« Reply #6 on: May 22, 2007, 02:41:52 pm »
FWIW, a "flush cut" bit has a bearing on the bottom and only cuts from the side. They were originally designed to cut laminate countertops flush with the sides of the counter.
A "pattern bit" has a bearing on the top, and may or may not have cutters on the bottom. In common usage the pattern is placed on top of the workpiece and the router is pulled tight against it, which doesn't require cutters on the bottom.
Straight bits often have cutters on the bottom, though I've seen some cheap ones that didn't. In any event, a straight bit isn't designed to be plunged into the work and isn't designed to clear chips from the cut. This may be a problem when creating a joystick recess, depending on how you setup the cut.
A spiral bit is almost like a drill bit. It has cutters on the bottom, that spiral up or down the sides of the cutter. It will cut while being plunged into the work and also clear the chips away from the cut.
The way I'd create a recess for a joystick is to create a template that ran along the outside of the area to be occupied by the joystick. I'd used a straight or spiral bit, along with a bushing/collar, and route out everything inside the template. This process is pretty well explained in the stickied thread by Timoe at the top of the forum.
BTW, I've never heard of a "pattern flush trim" bit. From the description, I'd expect it to have a bearing at the top and bottom and a cutter in the middle!  ;)
« Reply #7 on: May 22, 2007, 02:45:37 pm »
Wow, thanks, I learned some things from that post.
lordtodd75
« Reply #8 on: May 23, 2007, 07:51:47 am »
Thank you for correcting me. I suppose I have a pattern bit then, because it does cut from the bottom and it has a bearing up top. I actually did all of my recessing as well as cutting lexan for my CP with that one bit. If you want to do the same it will save you money to just buy the one bit and anybody that has bought router bits knows how expensive they are  :o
