Author Topic: Resetting/Fixing MAME controls  (Read 2234 times)
barnes
  • Last login:January 10, 2008, 10:15:29 pm
« on: May 20, 2007, 02:01:50 pm »
I made a stupid mistake.  :cry:
I was configuring MAME controls to my control panel I just finished so I can stuff it into the case I made, and finish it up.
I went into UI controls to change UI Select  to a combo of buttons to make configuring all the buttons quicker and easier. It didn't read my button presses first time, and resulted in 'none' as the button. I then hit escape on accident, and have locked the UI Select button to...well nothing. Now I can't get back into change it...well cause there is no select button.
I went roaming around through config files and couldn't find anything. What do I have to edit? What config file do I just have to overwrite to  get moving again?
Thanks alot! This final tuning of everything before I get into in the cabinet is insane! I'm loosing my mind.
(PS. I'm using Maximus Arcade if that helps. I bought it...so worth it.  :))
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Resetting/Fixing MAME controls
« Reply #1 on: May 20, 2007, 05:11:18 pm »
The mame file is cfg/default.cfg
You can delete it (and lose all the other stuff you did), or open it in a text editor and delete the port "UI_CONFIGURE".
Robin
Knowledge is Power
barnes
« Reply #2 on: May 20, 2007, 07:15:23 pm »
Fixed it. Thanks.
Is Maximus Arcade bad?
Havok
  • Trade Count: (+17)
« Reply #3 on: May 29, 2007, 02:58:26 pm »
I think he was just wondering why you put that bit in there. You had a Mame issue, not a front end one...
