Author Topic: How to Make Pointer Invisible  (Read 5602 times)
FrizzleFried
    • Idaho Garagecade
« on: May 15, 2007, 05:35:57 pm »
How am I able to make my pointer invisible in WinCab?
JustMichael
  • Mmmmm!! Cheesecake!!
Re: How to Make Pointer Invisible
« Reply #1 on: May 15, 2007, 09:23:13 pm »
I opened up the "jukebox.ini" file and inside I found:
# Mouse sets the mode of the mouse.  Mouse = Disabled
# will disable the mouse, Mouse = Enabled will enable the
# mouse with a visible pointer, and
# Mouse = Touchscreen will enable the mouse with an
# invisible pointer.  (If you prefer, you can use Visible
# and Invisible in place of Enabled and Touchscreen.)
# Note that touchscreens are currently only supported
# under DOS and Windows XP.
Mouse = Enabled
jp
  • Last login:May 23, 2007, 11:23:54 am
« Reply #2 on: May 18, 2007, 06:13:10 am »
i myself had setting : "mouse = disabled"
but at start up (dedicated jukebox ,>power on starts jukebox)
 the mousepointer is still visible (center of screen)
just a movement of the mouse makes it disappear
Chris
  • Moderator
    • Chris's MAME Cabinet
« Reply #3 on: May 21, 2007, 02:42:16 pm »
Try Mouse = Invisible.  Does that help?
--Chris
--Chris
jp
« Reply #4 on: May 22, 2007, 04:42:53 pm »
--Chris
ok, that worked out fine for me ,mouse is gone
thanks
Chris
  • Moderator
« Reply #5 on: May 22, 2007, 04:45:31 pm »
thanks
Great!  I'll add the original problem to the bug list... Mouse=Disabled should have worked too.
--Chris
jp
« Reply #6 on: May 23, 2007, 11:23:04 am »
"mouse=disabled" works,but i have to move the mouse one time (a little bit) and then the pointer disappears , and stays invisible
Chris
  • Moderator
« Reply #7 on: May 23, 2007, 12:47:05 pm »
You shouldn't have to move it though... it may be a slight variation among mouse drivers.  I should be able to fix it.
--Chris
