Author Topic: Jamma default buttons  (Read 2041 times)
Hawk Daddy
  • Last login:June 15, 2025, 03:10:44 pm
  • Only True Pimps Have Arcade Machines!!!
« on: May 08, 2007, 12:25:29 am »
so whats the defulat buttons for a jamma harness?  Is it 2, 4, 6 player buttons, I know it has a 1 player joystick, but not sure about the buttons.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Steel Talons 2 player helicopter game
BobA
  • What Me Worry?
Re: Jamma default buttons
« Reply #1 on: May 08, 2007, 12:57:59 am »
Standard is 2 joys 3 buttons per player.  More buttons require a kick harness.
Hawk Daddy
« Reply #2 on: May 08, 2007, 03:14:40 am »
Whats a kick harness?
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Grinch
  • Last login:May 24, 2007, 10:54:06 am
« Reply #3 on: May 08, 2007, 05:15:22 am »
It's just an extra wiring loom that has the connectors on it for the extra buttons. Also known as Jamma+ (And these looms are not standardized, pinouts can vary between PCB's).
I thought Jamma supports 1 joystick and upto 4 buttons per player.
« Last Edit: May 08, 2007, 05:21:37 am by Grinch »
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: May 08, 2007, 07:52:12 am »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Working: Not Enough
Projects: Too Many
Progress: None
shardian
« Reply #6 on: May 08, 2007, 09:21:28 am »
And before you ask, a J-pac has additional screw terminals for buttons 4-8.  ;D
Grinch
« Reply #7 on: May 08, 2007, 05:01:58 pm »
The 4th button pinouts are there to be used tho on the wiring loom.
http://www.coin.demon.co.uk/jamma.htm
« Last Edit: May 08, 2007, 05:24:50 pm by Grinch »
BobA
  • What Me Worry?
« Reply #8 on: May 08, 2007, 06:22:01 pm »
Button 4 can be on the jamma connector but in the most commonly used pin out P1/2 button 4 are labeled as not used and the kick harness is used.  An example of this is MK I which uses buttons 123 on the jamma but 4 and 5 are on the kick harness.
CheffoJeffo
« Reply #9 on: May 08, 2007, 06:26:26 pm »
Yeah, what BobA said (both times!) ... Button 4 is simply not part of the JAMMA standard, although some games do use the unused pins on the connector for Button 4. If you are looking at a "JAMMA game" with more than 2 players or 3 buttons, you need to look at the pinouts.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
Grinch
« Reply #10 on: May 09, 2007, 02:22:40 am »
Ahh cool, my cab didn't come with a PCB all I knew it was wired for 4 buttons via the Jamma connector.
 :notworthy:
