Author Topic: Tron centering grommet  (Read 1886 times)
Encryptor
  • Trade Count: (+34)
« on: May 07, 2007, 08:18:51 pm »
Does anyone know if the centering grommet in the happ version Tron stick will work in an original Tron joystick?
Encryptor
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
Re: Tron centering grommet
« Reply #1 on: May 07, 2007, 10:24:14 pm »
Do you mean the Happs "heavy duty trigger stick?"  It will work, but it's an 8-way restrictor.  You pretty much have to find an original, or convince one of our fabricating friends to make a new one to get a real TRON restrictor.
NoOne=NBA=
« Reply #2 on: May 08, 2007, 12:36:04 am »
He asked about the grommet.
I KNOW that the grommets will swap between the Tron, Discs of Tron, and Xenophobe sticks.
I'm not sure about the Happ ones though because I don't have one of those to the best of my knowledge.
I THINK they are the same as the Xenophobe sticks, except that they use microswitches in place of the leafswitches, but I can't swear to it.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #3 on: May 08, 2007, 06:59:58 am »
NO!!! MinerAl was entirely correct in his answer!! The original TRON restrictor (Gromet) is entirely different to the others. It's a 4 way restrictor, that is made of rubber and because it's made of rubber you can hit the diagonal 8 way positions if you push really hard towards the corners.
The rest of the sticks DOT, HAPP etc etc have 8 way restrictors.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: May 08, 2007, 07:57:43 am »
Encryptor asked about the centering grommet, not the restrictor.
My recollection matches NoOne's, although I only have Tron stick bits now.
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
Fozzy The Bear
« Reply #5 on: May 08, 2007, 08:54:51 am »
True... But the answer is that the Happ ones are subtly different. I've got one in front of me right now and it's not going to fit an original stick.
Why Happ felt a need to redesign it I'm not sure, maybe it was a licencing issue, who knows.
Best Regards,
MinerAl
  • duck
« Reply #6 on: May 08, 2007, 06:41:04 pm »
Ah.
Well then.
Never mind.
