Author Topic: Will Mame run from a CD/DVD? Can you Autorun the FE?  (Read 1748 times)
knave
  • Last login:March 24, 2026, 03:52:12 pm
« on: May 02, 2007, 01:03:43 pm »
Will Mame run from a DVD if the file structure is correct?
Or will the read only status cause problems?
Which version would be best for this if it will work?
I want to set up a DVD that will autorun, start joytokey and a FE. (oh suggestions on the FE?)
  • Last login:May 05, 2026, 10:44:49 pm
Re: Will Mame run from a CD/DVD? Can you Autorun the FE?
« Reply #1 on: May 05, 2007, 10:22:04 pm »
Mame should run from a dvd, you've just gotta remember to either set all of your cfg directories off of the dvd or have everything (and i do mean everything) setup right before you burn it.  Fes are the same way, most will run from a dvd but you have to have all the settings right first.
