Author Topic: Emutron lists  (Read 2263 times)
john160
  • Last login:April 28, 2003, 01:02:06 am
Emutron lists
« on: April 15, 2003, 03:54:20 pm »
Hi,
I installed emutron. Ran the config as in docs. I exported my list (john.lst) to the list folder. This list does not show up when I run emutron. Just the default lists that it came with.
What am I doing wrong.
John
john160
Re:Emutron lists
« Reply #1 on: April 15, 2003, 03:55:31 pm »
BTW I notice all of the default lists have a DAT file. the one I created does not. How can this be fixed?
Thanks Again
John
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Re:Emutron lists
« Reply #2 on: April 15, 2003, 06:37:15 pm »
Go to your category.lst in your list driectory and add it in that file.
john160
Re:Emutron lists
« Reply #3 on: April 15, 2003, 06:57:58 pm »
Thanks, I will give that a try.
Can I remove the others from the catagory list?
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
Re:Emutron lists
« Reply #4 on: April 15, 2003, 07:36:21 pm »
Yes, you can add / remove any files from the catagorys.lst file you want. The dat files are created automatically by EmuTron to maintain the positions in the list. So if you launch a game and come back, or exit the program and reload it later, EmuTron remembers where you were in the list. Deleting them doesn't hurt.
-PacManFan
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
john160
Re:Emutron lists
« Reply #5 on: April 15, 2003, 10:23:43 pm »
All that did was change the name on the list. It did not change the contents of the list. ???
John
PacManFan
    • Kymaera Home Page
Re:Emutron lists
« Reply #6 on: April 16, 2003, 05:34:28 pm »
John
I believe that the catagorys.lst file is set up so there is 2 lines of text in the file for each list you want to include. The first line is the name of the catagory, The line after that is the name of the list file.
-PacManFan
