Author Topic: wiring I-PAC2 with pressure mat switch  (Read 1944 times)
peersmall_4
  • Last login:May 03, 2007, 12:46:42 pm
« on: April 27, 2007, 08:55:37 pm »
 :dizzy:
i'm stucked on connectting I-PAC2 with pressure mat switch coding in Flash actionScript.
The mat has opend circuit. Is there any way to make it as a closed circuit?
please help,
p.s
BobA
  • What Me Worry?
Re: wiring I-PAC2 with pressure mat switch
« Reply #1 on: April 28, 2007, 04:30:21 pm »
Route it thru and inverter IC such as a 74h04
peersmall_4
« Reply #2 on: May 03, 2007, 12:46:42 pm »
hi BobA,
could you roughly explain how does the 74H04 work ?
will it break or convert the output? or ?
thanks
fjl
  • Pixels Rule!
« Reply #3 on: May 04, 2007, 10:05:19 pm »
Does just as the name implies. It inverts it's input.
Example; Input a turned on a switch, it outputs an off switch.
input Binary bit 1, the output becomes Binary bit 0
Input 5 Volts, the output becomes 0 Volts.
