Author Topic: J-Stick on a Nintendo CP  (Read 1489 times)
FrizzleFried
    • Idaho Garagecade
« on: April 27, 2007, 01:31:13 am »
Does anyone know if an Ultimarc J-Stick will fit on a Nintendo CP...or am I going to need to get some sort of adapter?
MaximRecoil
Re: J-Stick on a Nintendo CP
« Reply #1 on: April 28, 2007, 03:26:56 am »
Assuming the J-Stick uses a standard mounting bolt pattern, then I suppose you'd need this:
http://www.mikesarcade.com/cgi-bin/store.pl?sku=NJOYA
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #2 on: April 28, 2007, 09:22:37 pm »
If "Standard Bolt Pattern" means the standard for Happ, Wico, Betson, X-Arcade, and Industrias Lorenzo sticks (and I'll bet it does), then that won't do the job.  The J-Stik uses a Sanwa mounting pattern.
If you can find somebody with a sheet metal brake, you could probably get them to make you one with the proper dimensions for a case of beer or something.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: April 29, 2007, 05:49:07 am »
The J-Stik uses the same pattern as Happ and all the others. Most Sanwa sticks use the "narrow" pattern but the J-Stik has holes for this and also the wider, more standard, pattern.
See www.ultimarc.com/controldiags.html
Kremmit
  • - AHOTW -
« Reply #4 on: April 30, 2007, 12:50:35 am »
Well, shows what I know!
