Author Topic: What TV's are good?  (Read 3186 times)
rhett
  • Last login:November 19, 2007, 01:36:31 am
What TV's are good?
« on: April 25, 2007, 05:28:39 am »
I just ordered a UAII, and now my search begins for a TV to put in it.  This site stressed the importance of a high comb filter, and power return:
http://www.tmsoft.com/article-arcade.htm
It seems like people here get the best results using component connections.  It would be great if I could find a list of acceptible MAME TV model numbers that I could look for on craigslist.  Does anyone have suggestions?  Thanks!
I considered going with a real arcade monitor, but it looks like betson just raised their prices!
http://www.betson.com/products/IMP-44-4070-RT
dmckean
  • Last login:September 18, 2026, 10:10:04 pm
Re: What TV's are good?
« Reply #1 on: April 25, 2007, 05:37:47 am »
If you're using component you don't have to worry about a comb filter. I would look for a tube that does progressive scan over component if such a TV exists.
rhett
« Reply #2 on: April 25, 2007, 06:54:28 am »
Is there some way I could rig up "power return" on most TV's?  That is, have the power button permanently "pressed in", so I can turn the TV on and off by unplugging it and plugging it in?
Moose13
  • Last login:October 15, 2026, 08:12:48 pm
« Reply #3 on: April 25, 2007, 11:26:45 am »
I've have a Toshiba (27A41) power return TV I found on craigslist. I have it hooked up with S-Video right now, but just received the cables to try component connections tonight. I'm happy with the s-video, but with all the hype, I need to try it with component.
I've heaqrd of a user, in this borad, using toothpicks wedged in to hold down the power button, as you noted.   :dunno
http://forum.arcadecontrols.com/index.php?topic=37024.0
Biscuit
  • Last login:May 22, 2012, 04:02:28 pm
  • I'm flakey.
« Reply #4 on: April 25, 2007, 11:39:11 am »
I'd also like to hear from folks on this board regarding the make and model of TV they're using for their cabs so I can do a little craigslist scrounging myself.   I think ideally, we're all looking for the same things, right?
27" diagonal
26" width
S-Video and component input
auto power on
Can we get some testimonials?  :)  I love me some infomercials.
******** Edited ***********
Here's some of the suggestions found on this board.  I will add to the list as I find them.
toshiba 27a33
JVC 27530
« Last Edit: April 25, 2007, 12:03:32 pm by Biscuit »
ahofle
    • Arcade Ambience Project
« Reply #5 on: April 25, 2007, 01:47:30 pm »
Looks like it's still on sale to me?
If you don't already have a TV on hand and are going to have to lay down a couple hundred dollars anyway, then I would DEFINITELY go with the Betson.  You won't be sorry.
rhett
« Reply #6 on: April 25, 2007, 07:24:08 pm »
Are sony Trinitrons ok?  They are everywhere, and they usually have component in.  I also want to make sure that the TV is actually using the component and not just turning it to S-video.  Are flat screens worse than curved ones?
