Author Topic: What's the best way to drill through plexi and wood?  (Read 3183 times)
bk2099
  • Last login:November 09, 2021, 12:32:06 am
« on: April 24, 2007, 12:14:10 pm »
Hi, I just bought Dynamo HS-5 arcade control panel and I need to know what's the best way to drill holes into it? Do I remove the plexi and drill into the wood first? Or do I drill them both at the same time. And, is there a special bit I should use?
Sorry for the newbie question. Here is the control panel in question:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=004&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=140083467839&rd=1&rd=1
Thanks.
TOK
  • The Game Always Wins
Re: What's the best way to drill through plexi and wood?
« Reply #1 on: April 24, 2007, 01:42:31 pm »
The way that has worked best for me is to have a piece of scrap wood sandwiching the plexi.
I used a standard, sharp, 1 1/8" paddle bit and drilled the panel from below with the plexi in the middle and the scrap wood keeping the holes from blowing out and the plexi from cracking.
Its easy to work with but brittle and cracks if you put too much pressure on it. The wood keeps that from happening. I've read others just go lightly or use a hole saw with the drill spinning backwards.
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #2 on: April 24, 2007, 03:14:53 pm »
For small holes (bolts), use a normal bit and run the drill in reverse. Just slowly melt through and you shouldn't have any problems with cracking.
For larger holes (buttons, joysticks, etc), first drill the wooden CP with whatever bit you'd like. Then, clamp the plexi on top of the wood and use either a pattern cutting or flush trim router bit. Routers absolutely eat plexi with no real chance of cracking it.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
RichSorr
  • Last login:August 29, 2015, 07:27:00 pm
« Reply #3 on: April 24, 2007, 04:11:44 pm »
simple, just go slow and let the bit do all the work.
