Author Topic: full screen on a tv  (Read 1117 times)
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
full screen on a tv
« on: April 14, 2003, 07:08:35 pm »
i would like to no if there is a way for me to set Mame (any version) to display full screen for most/all of the games it supports. Currently i am trying to decide between Mame or Advance Mame. Thanx
It's all about the Pentiums
OSCAR
    • Oscar Controls
Re:full screen on a tv
« Reply #1 on: April 14, 2003, 10:17:35 pm »
When using a TV, I think probably your best results for full screen with most games will be to enable hardware stretch (assuming your video card supports it) and use the "RGB sharp" filter.  In the command line version of MAME, check the documentation in the Docs folder to see how to set the filter in the mame.ini file.  In MAME32, which probably isn't the best option available for TV display, you can enable these options right from the gui.
jakejake28
« Reply #2 on: April 16, 2003, 05:25:39 pm »
thanks, i tried it (on the command line version) and magic, full screen street fighter. man, sf alpha 3 rocks
