Author Topic: Removing paint from existing cAB  (Read 1072 times)
urbecrisch
  • Last login:February 23, 2026, 07:26:24 am
  • I was the S**T back in '82
« on: April 17, 2007, 07:25:08 pm »
What is the preferred method of some of you out there regarding old paint on a CAB.
1. Sand, prime, and then repaint
2. Repaint. F*** the sanding & priming
3. Use paint remover, prime, then paint
4. ? Other suggestions
I'm thinking of using paint remover but I'm not sure it's worth it.  If that is not advised I will sand, prime, and repaint.
Cheers!
Re: Removing paint from existing cAB
« Reply #1 on: April 17, 2007, 07:52:43 pm »
1
