Author Topic: How do I change the res when I can't see the screen?  (Read 1789 times)
Apollo
    • Eight Bells
« on: April 15, 2007, 06:45:32 pm »
Ok so I have accidentally picked some weird resolution using the arcadevga set up that my pc monitor can't handle (at least I think that's the problem). How do I change it back when I can't see anything on the the screen, I'm getting the 'no signal' error message on the screen. It was working fine, I messed with the resolution accidentally (you know, the little galaga icon in the task bar) and now nothing.
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
Re: How do I change the res when I can't see the screen?
« Reply #1 on: April 15, 2007, 07:11:15 pm »
safe mode?
If I do not respond to your post in a timely manner, feel free to PM me.
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #2 on: April 15, 2007, 07:41:31 pm »
try resetting everything back to the default settings.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
Kevin Mullins
    • Me on Myspace
« Reply #3 on: April 15, 2007, 07:56:48 pm »
What OS are you running? (Win98, XP, etc)
While it's booting up hit the F8 key (if I remember correctly F8 is the common one) to try and get into the menu that allows you to choose "Last Known Good Configuration"....or something to that effect.
Or "Safe Mode" as mentioned before from that same menu.
Apollo
    • Eight Bells
« Reply #4 on: April 15, 2007, 08:05:14 pm »
win XP, thanks folks I'll give it a try
