Author Topic: Ultimarc Easter closure and I-PAC new features!  (Read 5452 times)
Andy Warne
« on: March 24, 2002, 01:55:23 pm »
Hi All,
Just advance notice we will be closed from 1-15th April.
Still in contact by email though.
Then we re-open with these goodies:
56-input Ipac.
New I-PAC features: An interactive programming mode which needs no host software. The I-PAC communicates using "virtual typing" to the PC, running Notepad or DOS. Keys can be re-assigned using the control panel buttons and the keyboard.
New test mode: Displays any pressed or stuck keys and the codes to which they are assigned. No host software needed.
Code listing: Displays all inputs and the codes assigned.
These features will be on the 28 input version (no price increase!) and the new 56-input version ($65)
The new 56-input board has 2 CPUs with all inputs interrupt-driven with independent de-bounce counters. 2 separately programmable shift buttons.
Also a range of joysticks and buttons and a wiring kit with various coloured wire and terminals plus a crimp tool included.
All launching April 16th.
aramis
  • Last login:November 26, 2002, 09:24:04 pm
  • mame cab ALMOST done!
Re: Ultimarc Easter closure and I-PAC new features
« Reply #1 on: March 24, 2002, 04:13:30 pm »
So how about an "upgrade" package to those of us with the current 28 input version?  :)
I know that's not really a fair question, but I had to be the first to ask.  ;)
(I would be happy staying w/ 28 inputs, but would like the new soft since I run XP)
Oh, one other thing...you said "The new 56-input board has 2 CPUs with all inputs interrupt-driven with independent de-bounce counters."...is this a different architecture (i.e. improvement) over the current 28-input IPAC? Or just something that was necessary when upping to 56?
joe
  • Last login:Never
  • Livin' & Rockin'
« Reply #2 on: March 24, 2002, 07:34:59 pm »
yeah some sort of upgrade package sounds nice. i understand if its not possible.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: March 24, 2002, 09:05:40 pm »
Any particular reason for April 16th?  Over here, that is the day after our national income tax is due by.
Andy Warne
« Reply #4 on: March 25, 2002, 03:08:32 am »
This is not really possible unfortunately as the economics just don't work out! It's not really an upgrade, just a different product. I envisage most people continuing to order the 28-input version.
RingDawg
« Reply #5 on: March 25, 2002, 03:53:39 am »
Great, I can not wait to get the 56 input I-Pac in my hands.  So please do tell, for all of us crazy freaks that like to Connect Lots & Lots of buttons and controls, sould you still connect 2 of the 56 input I-Pacs together?  As easy a daisy chain as the old ones?
darkmanx
  • Last login:May 29, 2003, 04:46:57 am
« Reply #6 on: March 25, 2002, 06:21:31 am »
doesnt it just figure that like a week after i get mine there is a newer better version out.  :-/
WHELP! As if you knew what an eternity was. Grovel before your true master!
Frobozz
  • Last login:November 15, 2002, 03:16:45 am
  • I've been sane, but then I got better.
« Reply #7 on: March 25, 2002, 07:15:20 am »
Hey, I simpathize.  I just got mine Saturday  :P
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #8 on: March 25, 2002, 07:39:14 am »
Hey Andy, I assume this means no orders from the 1st to the 15.  Damn, just when I get back from the expo and predict I am going to need a few.
Oh well, I will order 3 or 4 now and play it by day after that.  Thanks for the warning.
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
Andy please read
« Reply #9 on: March 25, 2002, 08:27:57 am »
Will you still be working on a software update for those of us who still have the now old IPAC?
By update I mean a fix for the software to run in XP.
I am only curious, I will understand if this does not happen.
"The Manuel"
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« Reply #10 on: March 25, 2002, 08:34:16 am »
I love the new configuration!  Sounds GREAT!
I do have a question.  Will you be able to save the current settings (ie, get everythign perfect for zinc and then save it... then later you can just run a setup_for_zinc.bat taht you created and it's configured?)
joe
  • Last login:Never
  • Livin' & Rockin'
« Reply #11 on: March 25, 2002, 03:07:37 pm »
its cool, i understand. thanks for such a great product.
Andy Warne
« Reply #12 on: March 26, 2002, 11:38:23 am »
To answer some questions: Daisy-chaining 2 56 input boards, wow I cannot imagine why but there is no reason why not, except finding enough different key-codes to use might be a problem!
The interactive programming mode does not replace the existing programming utility, because it does not allow codes to be saved and downloaded on-the-fly. It does make it easy though to re-configure the board permanently, especially when only a few keys have to be changed.
We are still committed to the programming utility and getting a version which works in XP but this is proving technically very difficult as Microsoft not only bar direct I/O port access but also any writes to system devices such as keyboard and mouse, from a user program. The solution is being designed at the moment, by one of the world's top experts in the driver field (he has even written books about Windows drivers) so we'll get there! Once this problem is overcome, the actual win32 application needs to be written but this is probably the easy part!
1UP
  • Token Junkie
    • 1UPArcade
« Reply #13 on: March 26, 2002, 01:32:00 pm »
Good thing I keep an extra boot of Win98 installed (more than a few of my devices and programs don't like XP  >:( ) so I can still switch over for Ipac programming!  ;)
56 inputs, eh?  Don't know what I'd do with all those!  28 with a bunch of redundant buttons (pinball flippers, trigger sticks, 4way sticks etc) is more than enough for me!  Would sure like the built-in keystroke programming though...  :-/ sigh, just 4 months too early...
My other job...
Elkor
  • Last login:February 12, 2007, 12:42:50 pm
  • What did I just say?
    • Full Circuit
« Reply #14 on: March 27, 2002, 08:02:27 am »
Hey Andy!
those japanese joysticks might be just what I am looking for! (see joysticks thread here in the main forum)
do you have any specs on them yet?!  (mount depth, 4way, 8way, (different color balls!))  let me know, as I was just about to put in a jpac order so as to beat the closure date but I may put it off in order to get the joysticks (and buttons and stuff).  Hope you are getting a big stock too, because if these fit the bill they are probably going to go fast (and I may want first shot!)
-C
The sudden sight of me causes panic in the streets. They have yet to learn
-- only the savage fears what he does not understand.
                -- The Silver Surfer
